#261 |
If I'm remembering the article correctly, the Exemplar had four big vents on the back.
#262 |
Didn't see the smaller link at the bottom. Thanks.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#263 |
Now that is one big black speaker I could live with. Its like having a SR-71 Blackbird parked in the corner looking all moody
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home |
#264 | |
The Exemplar horns are more WG, so while a large room would still be ideal, they should sound more 'open' than an A7, etc.. Like I implied earlier, WGs are what's needed in most HIFI/HT apps, but the trade-off is they will tend to be large/deep and more expensive if a low XO point is used. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#265 |
Supposedly Tuesday is arrival time of 414's. I have 75ltr boxes that are currently sealed that I will port in an attempt to get an idea of sound in my room. I will measure all 4 and post results. Hopefully they are all close. Might have JBL LE15A back by then.
#266 | |
#267 |
Again, assuming the speakers are near/at the sound wall, seating [head location] is at thirds or 5ths, so 13.2, 14.66, 17.6 ft. Looks have nothing to do with it.
GM
#268 |
I wasn't saying looks had something to do with it, but speculating that in a long narrow room, continuing to back up further might not help because room reflections would come into play even more. The truth is, I could back up 25 feet from the speakers, but how many times would the sound waves bounce of the side walls, ceilings, and floors before getting to me.
#269 |
whatever you do , you'll end with some big honker in big tall TL box , with horn on top
one 15" per box will make your life easier if you were satisfied with your present liliputan spks , that will be certainly more than enough anything bigger than that will overload the room , meaning exactly what you wrote - that you'll need to back up more , to ensure blending of all drivers
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#270 |
I was thinking that I could try dual 414's in individual boxes similar to what you calculated, conected side to side, ( maybe single large version). I could try the single 15 route with the JBL. It is not an altec but has very similar parameters, big VAS, low fs, low Qt.
| Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn | HP8903B | Multi-Way | 11 | 22nd February 2011 07:20 PM |
| 50s - 60s Woofer/horn combo drivers | toptip | Full Range | 1 | 22nd June 2010 02:07 PM |
| Will this horn/driver combo beam? | Defo | Multi-Way | 29 | 10th May 2010 04:26 AM |
| adding dome tweeters to altec horn combo | ke4mcl | Multi-Way | 3 | 28th April 2009 03:34 PM |
| DE250 and Horn combo tested here | ttan98 | Multi-Way | 5 | 11th April 2008 02:12 AM |
