Horn/TL combo
Horn/TL combo
Old 4th November 2012, 06:38 PM   #251
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I moving head in stubborn fashion. The jig problem is no big deal. I will work it out. Be gone most of next week, so will be a while.
@ZM, thanks for the link. Buidling it is the fun part and how I learn what little i learn.
@Ra7, tthanks for the info. Indeed it does seem like the easiest to manipulate. Ibam strongly considering it.
...Shape the sound , Man!
Old 6th November 2012, 04:48 PM   #252
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Horn/TL combo
me likee this ( even if finding plans is not so easy task) :
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 6th November 2012, 05:00 PM   #253
GM is offline GM  United States
GM's Avatar
I wasn't aware that design details were ever published.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 6th November 2012, 05:01 PM   #254
Zen Mod's Avatar
Horn/TL combo
catch22
me neither
Old 6th November 2012, 05:43 PM   #255
TerryO is offline TerryO  United States
TerryO's Avatar
The Exemplar is/was an excellent sounding speaker. The last version I heard was at the final VSAC in 2008 (?) and it was absolutely excellent!
I certainly wish I had a pair. But I don't believe any plans have been released.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 6th November 2012, 05:44 PM   #256
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Horn/TL combo
Originally Posted by Zen Mod View Post
me likee this
me too
though I don't like to have edges right in front of the woofer
but sure, I know the fronthorn would otherwise be much bigger
only alternative could be a more shallow waveguide instead
but why would you need plans ? on the picture it looks pretty straightforward to me
Old 6th November 2012, 06:10 PM   #257
Vix is offline Vix  Yugoslavia
Vix's Avatar
I like
Old 6th November 2012, 06:39 PM   #258
TerryO's Avatar
Originally Posted by tinitus View Post
me too
The speaker evolved over a number of years and versions. However, if it's easy for you, that's great. Perhaps you'll publish the plans of your version?
I for one would appreciate it.
Best Regards,
TerryO
Old 6th November 2012, 07:53 PM   #259
fmena is offline fmena  Canada
Default Exemplar horn article
See link below for Sound Practices article:
Sound Practices Article Reprints
Cheers
Frank Mena
Cheers
FM
Old 6th November 2012, 07:59 PM   #260
buzzforb's Avatar
From glancing at it, it seems different in that there are no straight sides and it doesn't vent to the front, possibly being sealed. I could be remembering wrong, but did GM suggest that horn loading of the woofer needs a big room. I am going to be sitting 10-12ft away. I was looking at a front loaded born setup the other day that used the 515-16g, I think. Seems like the ceramic versions. An get away with smaller boxes. There are some 515-16g on the bay, but they don't seem to do as well S the 8g version that GM recommended earlier. Won't get the 414's until Tuesday, so hopefully I can redo horn jig and get at least one done. Be nice to start working with real stuff
Horn/TL comboHide this!Advertise here!
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 07:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 02:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 04:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
