Horn/TL combo
Horn/TL combo
Old 1st November 2012, 03:28 PM   #201
buzzforb is offline buzzforb  United States
buzzforb's Avatar
ZM,
I didnt see you had posted the pic of the 210. in brochure, they have it standing up, which i guess wouldnt work, considering its design. Fun it is.
JRKO,
Passive is defintely cheaper, but not as capable in simple form as dsp. I havent made that decision yet, but would probably go minidsp, as I have heard it is more favored than DQX2496. I tihnk the Behringer can be good, but needs mods, and i want to spend time on speaks, not crossover.
...Shape the sound , Man!
Old 1st November 2012, 03:30 PM   #202
buzzforb's Avatar
Originally Posted by GM View Post
Before considering MTM, please read/absorb/'wrap your mind around' what's in this article first: Biro Technology
Did you account for the increase in Qts the Pass amp's output impedance will cause? If not, you may get that 'flabby' bass you can't tolerate without mucho vent damping.
For best overall performance, woofer choices depend on the HF horn's directivity and XO point/slope.
GM
GM, I will be building the the SS version of F1 and F2 to see about working around Zout issue. Amps I am more comfrortable with and can work around, plus i got a ZM
Old 1st November 2012, 03:37 PM   #203
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Horn/TL combo
Originally Posted by buzzforb View Post
ZM,
dumbwakooyank
you have entire article , as far as I know
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 1st November 2012, 03:43 PM   #204
buzzforb's Avatar
Why change now.
Old 1st November 2012, 04:35 PM   #205
buzzforb's Avatar
GM
GM,
From the reading, I can see why one may hesitate to go the MTM route. What should be expect from a side by side and is this a reason to go with a single woofer? In those results, are we talking acoustic or electrical interaction? I noticed you had a pic of WWT MLTL, using 515b's, I believe. I would assume that configuration has its own drawbacks. THen again, EVeryone says it is all about tradeoffs.
Old 1st November 2012, 05:24 PM   #206
Zen Mod's Avatar
Horn/TL combo
lazyank , wakoo almost as ZM
Old 1st November 2012, 06:00 PM   #207
buzzforb's Avatar
Here is interesting link to 414 performance, mainly highlighting its abilities up top in midbass area.
Flex Your PCD Mettle: - Page 45
Don't know that I am taking advantage of the 288, although good extension does possibly allow for slower order xover. have read that most people encourage hig order crossovers, assuming this is for protection of compression driver.
Old 1st November 2012, 06:09 PM   #208
Zen Mod's Avatar
Horn/TL combo
you don't really need so much of protection for them , in home use
all about sonics , because even with few watts on them your ears will bleed
Old 2nd November 2012, 08:30 AM   #209
buzzforb's Avatar
Hope to have horn done my today. I decided to go with 290 as i wanted ootion of crossing lower than recommended for 480. Wil post pics.
Old 2nd November 2012, 09:08 AM   #210
buzzforb's Avatar
This looked like best config in unibox for single Altec 414.
Will have to use brick wall filter down low, as it exceeds xmax in mid 20's in box this size.
Tried larger box of 100l and it went deeper, but just maxed out faster.
Read some info on Bob Brines site last night and will play with MJK sheets more.
Horn/TL comboHide this!Advertise here!
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 07:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 02:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 04:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
