Horn/TL combo
Horn/TL combo
Old 26th October 2012, 04:46 PM   #131
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Here is the final shakedown. I will get 4 414A's. I will also either get the 515b or 515C from GPA. I will start wit the 414's. I will pit them against a 515. Then decisions will be made. I guess i should get a 416 as well to make it fair. THis is gonna be fun!
...Shape the sound , Man!
Old 26th October 2012, 04:53 PM   #132
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Blimey thats one hell of a set of headphones!!!
Whats the final product 4x bass + 2x Iwata? = Giant D'apolito?
If I'm not making noise, I'm making something to make noise
Old 26th October 2012, 04:54 PM   #133
buzzforb's Avatar
GM,
What you think about a dual 414 enclosure? Should I do .5 way and use sewcond driver to compensate for baffle step, or parallel them and use EQ to bring them up, gaining efficiency?
Old 26th October 2012, 05:05 PM   #134
buzzforb's Avatar
I have considerd this configuration, but I am not real sure how it would work in room.
Old 26th October 2012, 08:44 PM   #135
JRKO's Avatar
I do like the idea. On that one though I'd move the drivers toward the horn.
dual 15's would be a hoot. 12's would work well too I guess
glad your 'big' design is moving ahead full steam!!
Old 26th October 2012, 08:48 PM   #136
buzzforb's Avatar
Problem with MTM is XO. From what little I have read, It forces your hand on what kind of XO you can use. I am going to be driving these things with High Z amps, trying to macth impedances. Something along the lines of the F! or 2 and also variations of J2 and F6. All these can be setup to operate as low DF amps. Dunno. we will see. Gotta get the wife on board with the design first.
Old 26th October 2012, 08:53 PM   #137
JRKO's Avatar
would a minidsp help? one amp for bass, one for horns
Old 26th October 2012, 09:34 PM   #138
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Horn/TL combo
noticed this one yesterday
I like the classic design
apparently its with 8" coax
could be a CD/horn instead
the low mounted woofer could be a problem if you want it to play midrange
but a simple low stand-mount would be easy cure
btw, due to the small coax this one would probably be ok in the MTM you wanted
Old 26th October 2012, 10:12 PM   #139
JRKO's Avatar
looks like someone either copied or ruined an Altec 19
btw they've only used 4 of the 8 screw holes to mount the bass driver
Old 26th October 2012, 10:22 PM   #140
buzzforb's Avatar
Short and squatty wont work. I am going to be trading depth for width.
Horn/TL comboHide this!Advertise here!
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 08:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 03:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 05:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 04:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 03:12 AM
