Horn/TL combo - Page 11 - diyAudio
Old 24th October 2012, 10:25 AM   #101
ingvar ahlberg's Avatar
It would look like this:
The front part of floor in compression chamber has to be tilted down a bit and its 100mm wider than 12" version to avoid to hard compression in throat.
is that cat an approximation of open cell foam or a furry damping material?
Most of the time she´s an approximation of utter disaster.
But she´s heavily into speakers and other audio related stuff.
Ingvar
Old 24th October 2012, 08:18 PM   #102
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
1942 - Bugs Bunny says: "What's up doc" - YouTube
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 24th October 2012, 08:24 PM   #103
buzzforb's Avatar
I love those cartoons. They were kinda violent though.
I will have a pair of 416's and 288's on doorstep this week, hopefully. Gota decide on super tweet and horn profile. May do DIY Iwata or JBL clone first. Gotta fier up speaker testing gear and finish B3-1/2 or buy Behringer. Little worried I may need more adjustability than B4 can offer in terms of XO. What's ZM up to?
...Shape the sound , Man!
Old 24th October 2012, 09:26 PM   #104
Zen Mod's Avatar
go for Iwata
think big - who cares for those little WG's
I had a pair , sold it ...... but still have a pair of origigi 811B and pair of Iskra (better than origigi) 811B knock-off-s ............ they're just more fun to see , damped and lipp-ed
I'm up to cleaning workshop , and seeing my Yoda (and his prettier and cleverer other half ) tomorrow
so - stone bbq these days , with some nice wine
Old 24th October 2012, 09:36 PM   #105
buzzforb's Avatar
Enjoy your weekend and wine.
Old 25th October 2012, 01:56 AM   #106
GM is offline GM  United States
GM's Avatar
Originally Posted by buzzforb View Post
GM,
Is the muliway you posted pictures of in the Pub of similar size to your MLTL for the 416? Its funny how chamfering the front corners cand reduce the appearance of size. It seems to me that the 4552 was an unnecessary expense in that build, considering the presence of the 288. I guess it could be argued that he didnt need the 288 with the 4552. Also, i can see how the 414 would perform nicely as a midbass, but doesnt this kind of waste the abilities of the 515 and 416. Was the idea to bump the XO for the horn above the majority of the vocal range.
Which one? Westend’s?
As you can see, his is somewhat larger and judging by the specs I used, they were probably measured ones, but don’t currently have access to my notes beyond the MathCad sim:
AudioKarma.org Home Audio Stereo Discussion Forums - View Single Post - Altec MLTL with Model 19 drivers : “I will be using the Altec 811 horn and a Heil AMT1 tweeter on the top of the enclosure. The cabinet dimensions are 52 3/4" H x 30" W x 21" D, volume is 16 1/2 ft.^3.”
New project with GPA woofers-drivers : “The port is tuned to 32Hz. External dimensions are 700mm x 1150mm x 600mm. Internal volume for bass reflex is about 360 liters.”
“The crossover cutoff frequency are 200Hz, 800HZ and 10KHz.”
Yeah, the first example I recall seeing with a baffle slant cut was Harry Olson’s late ‘40s ‘reflex’ [original MLTL AFAIK], which was presumably a manufacturing cost compromise to the large round over popular back then for large ‘HIFI’ sets, Salon style speaker cabs.
Good RTR, CD, DVD, BD recordings can have sufficient HF to warrant a super tweeter with any 1” or larger compression horn and even with vinyl if a relatively wide ‘sweet spot’ is desired, so apparently Mike wanted his system to handle it all.
Yeah, at first glance, 200 Hz does seem a bit of a waste of a 515 or any really wide BW woofer, but it also allows plenty of XO overlap for best overall blending or ‘gapping’ them electrically [adding delay to the 414] to better align them on a flat baffle, though don’t know if he took advantage of it.
No clue why he XO’d to large format multi-cell at 800 Hz unless it had to do with maintaining a smooth off axis response and/or ‘gapping’ the XO points.
Anyway, I’ve published probably a dozen or more 416 series designs on the net since ’96 and many more in PMs with no ‘default’ alignment per se since the specs of OEM and re-cones have varied enough to require up to a ~40 ft^3 cab if driven with a matching impedance, though ~10–13 ft^3 has been popular as a compromise between LF extension/net bulk, with tuning usually being done by ear in room with familiar music.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th October 2012, 04:59 PM   #107
Zen Mod's Avatar
just keeping it on front page
couldn't wait to see pic of new arrivals
Old 25th October 2012, 07:56 PM   #108
buzzforb's Avatar
Here are the originals. I went a little crazy. I bought Altec 515B and G. Got some JBL123A in a trade. THey should make for good OB bass drivers.
Old 25th October 2012, 07:59 PM   #109
Zen Mod's Avatar
really wakooyank
please clarify- what you exactly bought , besides JBL123A ?
one 515B and one 515G , or ?
what's your intention now ?
Old 25th October 2012, 08:10 PM   #110
buzzforb's Avatar
Two 515b that need recone and two 515G. Haven't secured the G yet. I missed two pairs of speakers because of indecision. I wasn't going to do that again. Just sale what i don't want.
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 07:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 02:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 04:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
Copyright ©1999-2017 diyAudio
