Horn/TL combo
Horn/TL combo
Old 24th October 2012, 08:25 AM   #91
ingvar ahlberg is offline ingvar ahlberg  Sweden
ingvar ahlberg's Avatar
I like the idea of as big a box as I can get away with. As long as I can keep the proportions acceptable, I can get away with a big box.
An approach i like!
Why dont go horn/horn
The RLK is designed for 2 8" or one 12" but is easily adaptable for one 15"
This will go low, vell below 30 with the 416, and will play music with the dynamics, joy and of course, defects, inherent in large horns, still usable domestically, slightly below 10 cu ft.
I donīt know why the drawings get distorted but clicking them shows to scale.
Ingvar
Old 24th October 2012, 08:39 AM   #92
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Horn/TL combo
two drivers, side by side, I have seen it 30 years ago with 8" in a big Lowther Acousta
but can you actually do that, mount the drivers side by side
woofers, maybe just ok
but this is a 2way involving higher midrange and tweeter range
I dont know
Old 24th October 2012, 08:51 AM   #93
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
hey buzz. In view of the posts that should be arriving........
check out the 902 from GPA Altec Lansing GPA 802 804 806 902 909 902-8A 909-8A NEW | eBay REALLY good value for money AFAIC for NEW drivers that will go past 15khz
If I'm not making noise, I'm making something to make noise
Old 24th October 2012, 09:12 AM   #94
DeonC is offline DeonC  South Africa
DeonC's Avatar
Hi guys
Can someone post the pics for the actual design for GM's 416b MLTL? The link in the 'Altec 416b MLTL, design by GM' thread does not work anymore. It goes to what seems like a discussion of Iowa/Minnessota st. college football (I'm from South-Africa, so that's a very uneducated guess). The build thread on Audio Karma also does not show the design itself. And how adaptable is that design to other drivers? Or even modern GPA equivalents?
Thanks,
Deon
I don't suffer from insanity. I enjoy every minute of it.
Have a look at my favorite thread: Interesting YouTube video clips
Old 24th October 2012, 09:36 AM   #95
JRKO's Avatar
Just punching 'Altec 416b MLTL, design by GM' into google bring these up
Altec MLTL with Model 19 drivers - AudioKarma.org Home Audio Stereo Discussion Forums
GM's MLTL with 416-8B
Old 24th October 2012, 09:42 AM   #96
Had the same thought as i designed it, worried about strange or bad imaging,
still wanted to try as these 8" units sound realy good.
It works beautifully with very precise imaging and ambience if there is any in the recording, probably mostly due to that edges on transients and sibilance comes mostly from the HF unit and the brain hears direction firstly by this information.
And it has gained unconditional acceptance from even the most discerning ears.
Ingvar
Old 24th October 2012, 09:49 AM   #97
JRKO's Avatar
is that cat an approximation of open cell foam or a furry damping material?
Mine is more like 'pluff' - damn hair everywhere (i might start saving it and weave dressing gown......)
Old 24th October 2012, 10:01 AM   #98
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Music comes to life!
Ingvar,
Care to share what it may look like with a 15" woofer.
...Shape the sound , Man!
Old 24th October 2012, 10:04 AM   #99
JRKO's Avatar
Just a guess, but I'd go for BIG & fugly (he says watching on with interest from shadows)
Old 24th October 2012, 10:06 AM   #100
buzzforb's Avatar
GM,
Is the muliway you posted pictures of in the Pub of similar size to your MLTL for the 416? Its funny how chamfering the front corners cand reduce the appearance of size. It seems to me that the 4552 was an unnecessary expense in that build, considering the presence of the 288. I guess it could be argued that he didnt need the 288 with the 4552. Also, i can see how the 414 would perform nicely as a midbass, but doesnt this kind of waste the abilities of the 515 and 416. Was the idea to bump the XO for the horn above the majority of the vocal range.
Horn/TL comboHide this!Advertise here!
Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn HP8903B Multi-Way 11 22nd February 2011 08:20 PM
50s - 60s Woofer/horn combo drivers toptip Full Range 1 22nd June 2010 03:07 PM
Will this horn/driver combo beam? Defo Multi-Way 29 10th May 2010 05:26 AM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 04:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 03:12 AM
