Iphone Speaker
Iphone Speaker
Old 7th October 2012, 05:37 PM   #21
Bare is offline Bare  Canada
Don't think you are going to get a helluva lot of depth /bass/dynamics out of a Teeny driver. Unless one cobbles together a bespoke refrigerator/coffin sized Box to maximize every last erg of energy.
In which case simply buying a ~8" min diam driver would be a far simpler, easier to live with solution. Likely work better too.
Clearly your expectations are not meeting your size restrictions?
Decent headphones are a passable and often very good compromise while traveling.
Old 7th October 2012, 06:16 PM   #22
sergeloc is offline sergeloc  Canada
I think that Aurasound offer some tiny speakers with extended range and some fullrange drivers. Reviews are quite favorable. With 3 inches dia. you should have enough highs and they seem to provide decent bass.
Old 7th October 2012, 07:20 PM   #23
Basshunter is offline Basshunter  United States
Looking at my original suggested speaker from Parts Express, the DS135-8, the spec sheet states it requires 7.55 liters, or 460 cubic inches, ported. The tweet is sealed. Why are we talking about refrigerators? Thats a 7" cube inside dimensions! The whole system could be done within a box 16 x 8 x 8". What am I missing here?
Old 8th October 2012, 01:58 AM   #24
Dissi is online now Dissi  Switzerland
Yes, Vas of the driver is 7.55 litres. But Vas is not the required volume of the ported box. PE specifies 0.17 cu ft (=293.76 cu in).
Volume calculations seem to be tricky. I realized, i also have posted wrong values in reply #11. So let me resume what we have so far:
Assuming an overall size of 16 x 7 x 5 and 1/2" walls, after subtracting the volume of vent and driver magnet, we get a volume of 0.092 cu ft. This volume is further reduced by crossover, battery, amp, interface and connectors. We end at a remaing volume of maybe 0.02 cu ft.
Now the same calculation with new dimensions. The box is 16 x 8 x 8. After subtracting vent and magnet, we have a volume of 0.2 cu ft (=345.6 cu in). Minus the estimated value of 0.072 cu ft for the extras gives 0.128 cu ft.
Conclusion:
The small box doesn't work at all. The bigger box looks better. But the volume is still to small to use a 5" driver. It could work with a 4" driver. Maybe the Dayton DS 115-8?
Old 8th October 2012, 02:07 AM   #25
CLS is offline CLS  Taiwan
How about this:
http://www.diyaudio.com/forums/full-...ipod-horn.html
Old 8th October 2012, 02:14 AM   #26
Firstly, the dimensions do not include the amp, or battery. As stated, I would provide an additional space for those, but they are not important for speaker calcs. Secondly, the 7" dimensions are not in stone. The speaker says it needs 460 cubic inches, so 16x8x8. I'm not going to get hung up on the math. I was really more concerned with the pairing of the woofer and the tweet I selected, and what issues I would have designing a crossover.
Old 8th October 2012, 02:32 AM   #27
Let me clarify that I would do all the math necessary before I started this, its just not a concern at this stage of the design. The box size is well within an acceptable portable package.
Old 9th October 2012, 12:54 PM   #28
Hi Basshunter,
I made a simulation of your box, assuming a baffle of 16" x 8" and a volume of 0.17 cu ft. But I failed to find a simple crossover using the two Dayton drivers we are talking about. A crossver frequency of 3.5 kHz is a little bit too high for the woofer, and the tweeter requires a complicated filter.
Therefor I exchanged the tweeter and tried the Vifa BC25SC06-04, which allows a crossover frequency around 3 kHz. Doing so, we have a more relaxed situation and a classic 2nd order crossover works well.
Old 9th October 2012, 02:32 PM   #29
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
The horn idea just using the iPod speaker is not that silly, there's a very clever design using bamboo and its really not bad, all it needs is a small sub
Electricity-free Bamboo Speaker for iPhone 4 by Anatoliy Omelchenko — Kickstarter
Old 9th October 2012, 03:04 PM   #30
Originally Posted by Dissi View Post
Hi Basshunter,
Attachment 305467
Attachment 305469
You put a lot of thought into this. The drawings look good to me, and the crossover design is HUGE! Thank you!
I missed the Vifa tweet. It does look better. I was looking at ones 1" or less but this will work.
So how do you think it will sound? This covers 50-20,000 hz. in a small portable box.I have to think it will sound better than a Bose, or the like.
Iphone SpeakerHide this!Advertise here!
Looking for some help on an iPhone speaker setup ilov Class D 1 30th January 2012 08:01 PM
Portable ADC-DAC for iPhone 4 (iPhone IV) from Fostex - AR-4i + HP-P1 (AR4i + HPP1) tiefbassuebertr Digital Line Level 1 12th December 2011 10:45 AM
Iphone speaker - help needed :) Havoc08 Multi-Way 26 25th November 2011 09:56 PM
iPhone App? PBeyer Forum Problems 2 28th December 2010 06:25 PM
How to make your own iPhone Ringtone and transfer it to your iPhone directly? kity55555 Software Tools 1 20th December 2009 12:54 PM
