Active Crossover PSU - Page 2 - diyAudio
Old 23rd April 2001, 12:27 PM   #11
blmn is offline blmn  Brazil
blmn's Avatar
Bwoca,
So, your xover works with +/- 16V. I think you have a couple of possibilities here too:
- the virtual earth proposed in ESP demmands modifications in your xover and has little output current capacity. I think it would be a little hard to implement in your case, but, if you decide to go on this way, I can say usually +/- 16V circuits will work fine with +/- 12V;
- Ive built, many times, a simple self oscillanting circuit to feed this kind of gear. It works on 30 or 40 KHz and you can use 3 terminal regulators at the output to regulate it. Its easy to mount and you can find the components in any surplus store. If you were interested, let me know and tell me an e-mail address when I can put the schematics and other instructions. Of course, it demmands some electronic skills, but you can mount it without mess your xover and learn enough until felling yourself confident to connect it to the xover.
Old 23rd April 2001, 01:15 PM   #12
thanks alot, my email is bwoc@iprimus.com.au . Is the circuit you are talking about for turning 12vdc into the +/- supply rails? Again thanks alot
Old 24th April 2001, 01:19 AM   #13
blmn's Avatar
Yes, I'll send you some information.
active crossover: fir vs iir netchris Everything Else 3 29th July 2008 10:14 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 07:16 PM
PA vs DIY active crossover paulspencer Multi-Way 46 27th November 2004 02:25 AM
active crossover aaronboumans Analogue Source 4 31st May 2003 05:59 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 02:29 AM
Copyright 1999-2017 diyAudio
