I am fixing an old pair of ADS inc. speakers, the surround on one speaker has come disconnected from the frame. as far as i can tell the surround type is a basic rubber (butyl?), not foam. what kind of glue should i use? epoxy? rubber cement? Elmers? help me out here guys. much appreciated.
mike |
#2 |
Parts Express sells a one ounce bottle of "special" speaker repair glue for $5.95 US.
Or you can go to a discount craft store and buy a glue that claims to produce "a flexible water resistant bond to difficult to glue surfaces." You can buy the craft glue in an 8 ounce bottle for $4.00 US. Inside the bottles the glue is almost identical. Two names are Beacon Gem-Tac and Crafter's Pick The Ultimate. Good luck, Mark |
| About INPUT RESISTER separated from ground | turnA_zpoint | Solid State | 8 | 24th June 2010 01:36 PM |
| GC hums with separated PS | wchick | Chip Amps | 1 | 6th May 2007 10:09 AM |
| Separated or Same Chamber Box? | suprastar17 | Subwoofers | 2 | 19th April 2005 02:32 PM |
| Gluing rubber surround to paper cone | biff_loman | Multi-Way | 4 | 10th August 2004 01:13 AM |
| Should I keep these ports separated? | Stephen D | Subwoofers | 4 | 15th December 2003 01:21 AM |
| Page generated in 0.04927 seconds (80.50% PHP - 19.50% MySQL) with 10 queries |
