When it comes to speaker building, what best defines the term "DIY"
Old 5th October 2012, 03:07 AM   #11
5th element is offline 5th element  United Kingdom
5th element's Avatar
With loudspeakers there is a large range of what people would probably consider DIY.
One person might consider building a Zaph kit, complete with Parts express/Madisound cabinets a DIY design. This is a DIY effort to some extent as you're certainly going to tick the box that would qualify getting more for your money then if you were to buy a completely assembled pair of loudspeakers on the commercial market, but it does sort of stretch the definition of DIY a bit thin imo.
Now if you were to use Zaph's own design, but build the cabinets all by yourself and even if they didn't end up looking as good as the PE/Mad boxes, I would consider this more of a DIY effort then the first.
Then you've got the person who buys all the drive units and crafts their own cabinet and once built, measures everything and then designs their own crossovers. This is about as DIY as it gets, but depending on the designers competency you might end up with a cabinet that looks worse then madisounds and a crossover that's poorly implemented, but at least it's all your own work!
Finally you've got another choice which would be someone like Zaph for example, buying all of the drivers and cabinets from PE/Mad and then designing the crossover himself. Personally I consider the selection process for the drive units and then the associated design of the crossover, the true heart of what it means to make and design your own loudspeakers. This is the hard part to really get right and for that reason would make this choice qualify almost as high as if you had built the cabinets yourself too.
Part of this though is recognising your strengths and your weaknesses and working around them to give you what you wanted. Sure, buying PE boxes and a Zaph kit might not really be doing much true DIY, but if you've asked around on DIY audio for help in making an informed decision about which loudspeakers, from which designer, would be the best from a technical point of view AND in the process you've learnt a little more about loudspeaker design by researching these things and asking those questions, then there's no reason why this shouldn't be considered DIY.
I get the most fun out of choosing the drivers and designing the crossover and then seeing/hearing what the results are like. If someone else wants to build and finish the cabinets for me, then that's fine by me. I personally will consider the majority of the design my DIY effort with a bit of help from the person who built the box. And the person who built the box could probably also consider the majority of the design their DIY effort with a bit of help from me. Our opinions on that would be radically different, but at the end of the day we both ended up satisfied and most importantly would have scratched what they call 'the itch' where we are now hopefully satisfied to not feel immediately compelled into wanting to build something else!
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 5th October 2012, 03:30 AM   #12
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
There are 2 ways to look at DIY..... design it yourself or do it yourself. Both fit the term well.
No longer DIY active
Old 6th October 2012, 12:43 AM   #13
Remlab is offline Remlab  United States
The thing that really got me thinking about this subject is the latest "high end" efforts by Sony;
https://dealersource.sel.sony.com/ds...inal_LoRes.pdf.
A company that has always used their own drivers, cabinets and components, outsourced everything this time, except for the intellectual effort by one of it's own engineers. So it made me think; is it ultimately the "intellectual effort" that allows you to call a design your own? So far I've gotten some very good responses.
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain
Old 6th October 2012, 12:49 AM   #14
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Don't forget to add in all those people who buy the cheaper end speakers and then modify them by adding bracing and fibrefill ( always a good cheap fix IMO ) or changing crossover components, tinkering is also DIY
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 6th October 2012, 12:54 PM   #15
afa is offline afa  Australia
pure semantics, if you bothered to ask the question you need to get out a bit more
Old 6th October 2012, 02:35 PM   #16
david crewe is offline david crewe  United States
david crewe's Avatar
Why DIY? Because you can't buy these.
David
Old 6th October 2012, 02:43 PM   #17
Pano is offline Pano  United States
Pano's Avatar
When it comes to speaker building, what best defines the term &quot;DIY&quot;
I remember those cool speakers!
Old 6th October 2012, 04:04 PM   #18
As far as I'm concerned that's the only bit that really matters, as ultimately that's the thing that's going to determine how well your loudspeakers perform. Where you get the raw components from doesn't really matter, it's how you use them that really counts.
An example where form and function are both following each other. My only criticism would be that the C2C spacing is a little high and I'm only saying this because it looks like it would be possible to reduce it.
Old 6th October 2012, 07:25 PM   #19
Sounds like someone who built a kit! Or maybe designs them?
Old 7th October 2012, 12:45 AM   #20
CLS is offline CLS  Taiwan
One can be a craftsman, a designer, or a (scientific) researcher.
When it comes to speaker building, what best defines the term &quot;DIY&quot;Hide this!Advertise here!
"Tired2way" speaker building. Starre Multi-Way 1141 30th May 2017 07:52 PM
Building first speaker - "best" design? EricPtek Multi-Way 12 23rd November 2011 12:21 PM
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
the term "Time Symmetry" means....?? redrabbit Parts 1 13th February 2008 11:11 AM
A new term.. "Speaker widow" Dave Bullet Everything Else 0 9th August 2007 05:05 AM
Copyright ©1999-2017 diyAudio
