two speaker sets, one cab - Page 3 - diyAudio
Old 4th October 2012, 09:49 PM   #21
diyAudio Member RIP
2 x Quality 3 Way Crossover Filters for Speakers 400W | eBay
Not a good idea. Its too simplistic. Wrong x/o points for the drivers.
2x KEVLAR LOUD SPEAKER CONE 6.5" 16cm 250W MAX 8 OHMS HIFI WOOFER 902.423 | eBay
Not a good idea. Substantial for the price but not much else.
The quality of the drivers (skylab) is an unknown quantity.
Peerless SKO130 5" Bass/Mid KEF B110 alternative | eBay
Reasonable, but using two 4ohm mids is not a good
idea due to several reasons, not least of all expense.
Peerless DT-105 / LR10DT 25mm dome tweeters PAIR | eBay
Decent tweeters.
Overall the original 6.5" 2 way you posted will work a lot better than the
above, which will requires zobelling and L-pads to be added to stand
a chance of working well, and even then the x/o points are all wrong
for the above drivers.
There is also a 8" 2way :
Speaker kit 3 : Peerless SKO204 + DT105 + crossovers ! | eBay
Another very good value kit.
Bass driver specs :
Impedance: 8 ohms
Sensitivity: 92db
DC res (Re): 6.1 ohms
Power: 70 watts nominal
Resonance (Fs): 40hz
Frequency range 38-5000hz
Compliance (Cms): 0.78 m/N
Moving mass (Mms): 17.8 g
Qms: 4.23
Qes: 0.47
Qts: 0.43
Vas: 58.2 litres
Force factor: (Bl) 8.11
Baffle cutout: 186mm diameter
Chassis diameter: 224mm
That is probably your best bet. A 40L box tuned to 35Hz should work
very well. Something like the Audionote AN-E box (its rear ported) :
If that is too big go with the 6.5" kit. 20L tuned to 40Hz is good.
rgds, sreten.
Old 5th October 2012, 05:18 PM   #22
Sreten thanks for your reply , but as they say fools rush in .
ive ordered the speakers but changed the cross over to this one
ebay 230781332299
hoping to more closely match xover , the 2x mids to connect in series for 8 ohm,
had to order speakers now to get the mdr free and get cut to match speaker requirements,
I thought i could house drives now with rough xover and make xover later
I have sound meter , hoping I could signal gen from pc would that work ?
Old 6th October 2012, 12:18 PM   #23
diyAudio Member RIP
To put it bluntly your going to end up with something that sounds
like garbage compared to building the good value 8"/1" 2 way.
Well, there are two ways of learning and you've chosen
what I consider the initially very frustrating approach.
I wonder how you have arrived at the speaker boxes for this ?
rgds, sreten.
Pair of Quality 3 Way Crossover 400w RMS 8 Ohm Speakers | eBay
The previous choice is far better value for cannibalising components.
speaker cab builder tsgraphics Construction Tips 0 9th August 2010 09:01 PM
New Flat Panel Speaker 2x2 speaker set for sale (3800 sets) Tenacious Vendor's Bazaar 0 18th June 2010 01:17 AM
Speaker cab wiring...need help! mrd34d Instruments and Amps 3 31st January 2010 04:29 PM
3-way speaker cab project bobbymo Multi-Way 1 11th April 2008 07:55 PM
1x12 Speaker cab mattisa_lamma Multi-Way 1 22nd January 2008 10:39 AM
Copyright 1999-2017 diyAudio
