Looking for active bass equalisation - Any equivalents to "Golden Flutes" ? - Page 2 - diyAudio
Old 5th October 2012, 12:38 PM   #11
clubsport911's Avatar
You could rig up a Linkwitz transform circuit.
Look here for the theory and the project and a spreadsheet for calculations
I like this ! Seemingly simple, but my only issues is somehow discovering the data on the drivers and cabinet.
The deisgners of the 105/3's are not exactly on display !
Good call though - thanks
The older I get, the fitter I was !
Old 5th October 2012, 12:44 PM   #12
DreadPirate's Avatar
You could pick up an equalizer for some of the older Thiel speakers such as the CS3.5. These go for around $100. Some people ditched the equalizer and used the "Golden Flutes." It is possible that the GF were made for specific speakers, but I can't recall. This Thiel equalizer has a switch to boost 20 Hz or 40 Hz, see attached graph for measured response, pilfered from the stereophile site:
Thiel CS3.5 loudspeaker Measurements | Stereophile.com
Old 5th October 2012, 04:47 PM   #13
weltersys's Avatar
Originally Posted by clubsport911 View Post
Sure... I have a 400W MF amps (40A current output continuous), MF Pre-amp and KEF 105/3's. The 105/3's are bandpass Coupled Cavity Designs and also were configured to work with and without the KEF KUBE 200 active equalisation.
I could search forever to find a KUBE 200 or perhaps take advantage of higher capability (lower cost ?) more modern electronics that have even less insertion loss. I definately do not want to touch the midband. On my system, it's great.
The 105/3's frequency response being -2.5 at 49 Hz would indicate that even moderate boosting below that point would probably just result in over excursion, bandpass designs often roll off at 24 dB per octave.
Adding a sub for frequencies below 50 Hz would take care of the lack of LF without adding distortion.
Old 5th October 2012, 10:42 PM   #14
Yes an L-T transformed sub woofer is probably your best option.
rcw
4-way Active (3+1 way) TL 15" 8" 3" 1" cka3o4nuk Multi-Way 44 25th April 2011 02:26 PM
Please recommend a 4 or 5" FR for Open baffle w/ active bass augmentaion JandG Full Range 19 9th July 2010 05:54 AM
question regarding "golden ratio" Jeb-D. Full Range 3 28th May 2006 10:39 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
Active Room Equalisation annex666 Everything Else 15 13th January 2003 12:24 PM
Copyright 1999-2017 diyAudio
