Driver break-in - diyAudio
Old 2nd October 2012, 09:19 PM   #1
Default Driver break-in
I have a pair of 7" scanspeak woofers i just got and was curious if i should break them in before installing them into my enclosure or should i just let them break in through music.
Old 2nd October 2012, 11:00 PM   #2
weltersys's Avatar
If you are planning to tune the box, break in is a good idea prior to that .
If not, don't bother, unless having the speaker's sound change slightly over time bothers you.
Old 4th October 2012, 06:25 PM   #3
Back in the day, my friend would "break-in" woofers before installing. He ran a signal generator at 20 Hz, but kept the amp volume reasonable, and let them go for hours. Is that what you meant? Not sure I would bother... but he was a fanatic. I would just go ahead and install the woofers without break-in.
Old 4th October 2012, 08:29 PM   #4
weltersys's Avatar
Using pink noise (which contains all frequencies) is a bit better for break in than using a single tone, but 20 Hz at Xmax will "get er done" pretty fast.
Driver break-in marec Full Range 15 11th January 2008 02:06 PM
Driver 'break-in' period Cal Weldon Multi-Way 124 4th June 2004 03:50 PM
Driver break in bhg41088 Multi-Way 4 9th April 2004 10:56 PM
DIY driver break-in? Phil O.son Multi-Way 10 21st October 2002 05:32 PM
Copyright 1999-2017 diyAudio
