#51 |
Hi-Fi is about realistic sound reproduction ever since Hartley invented the term in 1927
#52 | |
Is it conveying the "realism" of the original recording, even if it's terrible? Is it taking what we're given on a recording and trying to juice what our mind perceives individually as "real" out of it? Different people have different ideas about which it should be. It's just one of those things that has a right and wrong answer depending on who you ask. |
#53 |
I don't want to sound defeatist in my answers, but I just don't think #1 is really achievable. For me, it's not even desirable. It's not wrong, it's just not my concern because I can never know what it was.
Maybe to achieve #1 we could
#54 | |
reality is intersubjective, our perception is fundamentally determined by our physiology and Hi-Fi is for humans - beings with human hearing physiology I am with Linkwitz: "Unbiased listeners have no difficulty recognizing accurate sound reproduction, even with hearing damage or with hearing aids" [SL obviously means realistic when uses the adjective "accurate"] realism is not about microscopic details or reproducing of >20 kHz overtones a lot of the so called HiFi equipment is pretty good at reproduction of microscopic details or reproducing of >20 kHz overtones |
#55 | |
In all the other cases the 'realism' can only be finalised by the influence of the interaction of the speakers and the listening room. This of course gives a lot of freedom to the end user for adjustements with his speakers, room etc..
Home page If our hearing would be accurate, we would be hearing two loudspeakers. |
#56 |
Well, what I mean by that is really that, depending on which part of process we're after a faithful reproduction of is what determines an individual's definition of realism.
For instance, someone might say that a colorized version of a black and white movie is more realistic, however to another individual, realism might mean "seeing it exactly as one might have seen it in a theater on opening night." We can attribute the same things to audio recordings, it depends on the individual's definition of realism. |
#57 |
I think you're misunderstanding the use of the curve. It's not intended to alter recorded content ... it's intended to persuade a given set of loudspeakers into a specific in room response. It's a "house curve".
#58 | ||
![]() Quote:
In short: you want it to sound realistic & alive in your room.
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home |
#59 |
Coloring a B&W movie is more like converting a mono recording to stereo, there is some justification for both. But changing the audio playback is equivalent to readjusting the color on a color movie to make it more red or grenn because you "like it better". There is one color setting that "reproduces" the original best and thats all. Its not a preference thing.
#60 |
ooo yeah I like that reply
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
| background music sound system for museum | rspfau | Construction Tips | 3 | 6th August 2012 03:39 AM |
| Full Music 300B solid plate sound fine ? | aldovan | Tubes / Valves | 2 | 5th July 2012 04:31 PM |
| What music/sound style for 845 tubes? | ksporry | Tubes / Valves | 12 | 20th March 2011 02:36 PM |
| Listening Room for your Sound of Music | lineup | Everything Else | 2 | 17th August 2008 10:32 PM |
| cheap SPDIF-out sound card for music, movies, and gaming? | Dartagnan | Digital Source | 7 | 11th October 2004 03:15 PM |
