Dynamics, brute force and resolution with tiny feet.
Old 2nd December 2012, 08:36 PM   #81
ingvar ahlberg is offline ingvar ahlberg  Sweden
ingvar ahlberg's Avatar
The tweeters are delivered in matched pairs with actual fr meassurements, nice i think.
Managed to go slow on the glögg, switched to beer instad.
Been a really nice and good sunday with wife and friends, turning in now, have to be really early tomorrow.
Ingvar
Old 2nd December 2012, 08:49 PM   #82
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
Originally Posted by ingvar ahlberg View Post
-8 deg c, a clear blue winter sky, zero wind, quite a bit higher bloodconcentration in the alcohol system, things look different.
Ah, I wish it was that warm up here as well. Today was the day for the annual christmas market in the village and standing outside in -18c for several hours was not the best thing I've done this week.
Ingvar, you sent me the mail/package, right?
The Jake speakers look very cool, maybe something my dad should build?
My audio and DIY blog: http://phimusic.blogspot.se/
Old 3rd December 2012, 12:53 AM   #83
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Yes back in 2004 when I was deciding what drivers to purchase for my MTM's I considered the MDT33's for a while (which also came in matched pairs). Terry who I mentioned earlier actually had his own custom versions of those (I think that they may have been horn loaded like the dms37's I ended up getting). The reason for the custom version was to get time alignment with the MW144's without the need for a sloped/stepped baffle.
I suspect that the combo of a CAT378 and a pair of CAW538's should work well together (as they seem to be the newer versions of the mw144 and dms37), you need to surface mount the woofers and flush mount the tweeter for time alignment. Again the info on the MW144 and DMS37 combo came from Terry who had design input into the DMS37 tweeter. Note that I am assuming that the kept the synergy of the old when they designed the new!
Any intelligence I may appear to have is purely artificial!
Some of my photos
Last edited by wintermute; 3rd December 2012 at 12:55 AM. Reason: add links to datasheets.
Old 3rd December 2012, 01:03 AM   #84
phivates is offline phivates  United States
The Morel haters will return. Sad people, for whom good isn't good enough. I like the sound of simple filters, but I aspire to simplicity.
Old 3rd December 2012, 06:26 AM   #85
Port is 330mm long, not 418, don´t really know where that figure came from.
Nice to get this whith the hf units.
Why not, they are eminently fun for playing Tony Joe White loud, really loud.
Ingvar
Old 4th December 2012, 07:41 PM   #86
As the box is so utterly small there´s hardly room fo the intake panel.
Worked a bit too much so not enough time to play and listen yet but so far, ridicously fun, especially when playing loud, seems the Morel drivers are dull when playing really soft when they´re not broken in yet.
Measuring is suddenly something uncomprehensible when hf units are of unknown and very wide dispersion design, Horns and amt´s You know how they beam, know reflections, at least somewhat, but how do You meassure really wide dispersion speakers further away than 1m and now what You meassure, room or speaker?
On the other hand, i don´t actually care, these are among the most rewarding, happiest speakers i´ve listened to in a long time, and i suppose low level dynamics will improve with break-in time just as the case was with the Oy speakers.
Ingvar
Ingvar
Old 11th December 2012, 07:11 PM   #87
New toys arrived today, waited a long time.
Box larger than i expected, drivers too, there was no mechanical info available from Mundorf, they´re handbuilt and it has taken quite some time before they finally relased them. Need to redraw first testbox, will be with the Morel EW638, i think.
Airmotiontransformers are, in my experience, so far the best technology for hf transducers, the Heills and Beymas TPL units are fantastic, so this will be really fun to try out.
Ingvar
Old 11th December 2012, 07:38 PM   #88
badman is offline badman  United States
badman's Avatar
A bit uncertain about where You find this broad 10dB dip in the midrange?
1500-4kHz. -20 goes down to a little above -30 (smoothing would make it look more like 7dB perhaps)
This looks like partial phase cancellation. The filter, in any case, could use some refinement, as this component is likely in the anechoic response as well.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 11th December 2012, 08:04 PM   #89
I see that i failed to post later measurements of the Oy speakers here, still there is no 20 or 30dB dip in that first posted measurement of a speaker played for about 1 hour, and first test x-over.
This is the latest measurement of th Oy speaker:
Ingvar
Old 11th December 2012, 09:24 PM   #90
badman's Avatar
Nobody said there was a 20 or 30 db dip- -20 and -30 were the y axis references. Newer version looks much smoother (with smoothing) but I'd want to listen off-axis to avoid that large rise.
Dynamics, brute force and resolution with tiny feet.Hide this!Advertise here!
Brute force in a small cabinet... moray james Subwoofers 5 27th September 2012 07:28 PM
Making a low distortion cathode follower preamp by brute force bigwill Solid State 0 12th May 2007 04:53 PM
help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er jarthel Tubes / Valves 9 30th May 2006 07:47 AM
Help on Brute force Ryssen Tubes / Valves 5 2nd May 2004 10:07 AM
