Dynamics, brute force and resolution with tiny feet.
Old 1st December 2012, 11:48 PM   #71
ingvar ahlberg is offline ingvar ahlberg  Sweden
ingvar ahlberg's Avatar
Strange then , to add that comment right after a measurement of another speaker where You would be hard tested to find much outside a +/- 3dB span between 50-10k, but that seems to have become the new diyaudio environment, an absolute negativity, a lot of now it all, a lot of you cant do that, not much left of the friendly open and helpful comunity that was here when i, by mistake, fell out of here last time.
Whatever these knowitalls think, these spakers are good, to my ears, the Morel drivers are really good so the selfaclaimed experts can surely do something even better than my humble excersises whith them.
I thought this was a place to share, help and encourage, that was utterly wrong, this is a place where narrowminded nobodys thrive on trowing their frustration on anyone who present an idea or design that departs from their main route.
There´s nothing worse, or more dangerous, in this world than morons.
Signing out, for good.
Ingvar
Ingvar
Old 2nd December 2012, 12:15 AM   #72
system7 is offline system7  United Kingdom
system7's Avatar
Ingvar, take a deep breath and cool down. I nearly made my own signature: "Casting Pearls before swine..." on occasion.
Now having just been involved in an Epos ES-12 thread where there is no bass filter whatsoever, and only a 2.2uF cap on the tweeter, there is something to be said for your simple filters.
http://www.diyaudio.com/forums/multi...fications.html
Can we hear more about your new little speaker? It looks nice. Birch ply box?
Best Regards from Steve in Portsmouth, UK.
Last edited by system7; 2nd December 2012 at 12:29 AM. Reason: Corrected Typo, just my Aspergers...LOL
Old 2nd December 2012, 12:15 AM   #73
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Ingvar,
Come on over to my thread. Your input and wit is much appreciated over there. I am not saying i will listen, but i do enjoy the company. Plus, I like your boots
...Shape the sound , Man!
Old 2nd December 2012, 01:22 AM   #74
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Yes but perhaps he read the first couple of posts and posted his reply before reading the rest of the thread As I said the first graph (as far as I am aware) was in room, so of course it is going to have big dips and peaks
The latest speaker looks very nice indeed Ingvar! Please keep posting
You might want to PM Terry (phoenix358) diyAudio - View Profile: pheonix358 he hasn't been online for a while (if he had I'm sure he would have posted in your thread). He has a lot of experience with Morel drivers and pretty much does as you have been doing. ie very simple crossovers.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 2nd December 2012, 07:55 AM   #75
-8 deg c, a clear blue winter sky, zero wind, quite a bit higher bloodconcentration in the alcohol system, things look different.
We´re closing in on that time of the year when it´s even more important to behave well towards others, something i have a hard time with, but i´ll try my best.
The tiny Jake speaker, designed for our guestroom and on demand from diy friends in Sweden, is indeed built in 18mm birchply.
Net volume about 13L, port 200x25mm, 418mm long. As the Morel drivers can handle quite some power these can play really loud on demand, thus the sidewalls are lined with 0.5mm leadfoil to overcome the "transparency" the ply has around 400Hz.
The lf unit seems very well built, the cone is actually turned.
Back soon, have to heat up some glögg (gluewein).
Ingvar
Old 2nd December 2012, 08:21 AM   #76
just another
wintermute's Avatar
Easy on the glog I don't think you mentioned which drivers these were Ingvar?? I don't recognise either of them.
Tony.
Some of my photos
Old 2nd December 2012, 08:40 AM   #77
The drivers are, lf EW638 and hf ST728.
Will try to go easy on the glögg.
Ingvar
Old 2nd December 2012, 09:43 AM   #78
just another
wintermute's Avatar
You did step it up a notch (or three) especially on the tweeters!! I like the look of those new uniflow baskets, much less restricted than the traditional morel drivers.
Tony.
Some of my photos
Old 2nd December 2012, 09:52 AM   #79
Me too, those in the avatar are Sarria, from Mexico, only use this brand and Sendra, handmade in Spain. As this is the only kind of footwear i use and they are suboptimal in the Swedish westcoastwinter with rain and mushy snow i wear out at least two pairs a year.
Ingvar
Old 2nd December 2012, 01:33 PM   #80
system7's Avatar
Ah, good. Everybody chillin' out to their favourite ABBA record now. ABBA could have been named FABB, of course. Harmony restored and no-one ripping apart low order crossovers.
Lead sheets, eh? Joachim Gerhard likes a solid metal base screwed on to his Sonics Anima speaker. Must do something similar...
Time alignment helps with low order filters. You wire the tweeter out of phase and phase is then really good:
Those Morel drivers are top notch:
Morel EW 638 Woofer
Morel ST 728 Tweeter
The woofer reminds me of the Visaton W200S 4 ohm frequency response which works rather well on first order, albeit a bit of cone breakup getting through.
Dynamics, brute force and resolution with tiny feet.Hide this!Advertise here!
Brute force in a small cabinet... moray james Subwoofers 5 27th September 2012 07:28 PM
Making a low distortion cathode follower preamp by brute force bigwill Solid State 0 12th May 2007 04:53 PM
help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er jarthel Tubes / Valves 9 30th May 2006 07:47 AM
Help on Brute force Ryssen Tubes / Valves 5 2nd May 2004 10:07 AM
