Dynamics, brute force and resolution with tiny feet. - Page 3 - diyAudio
Old 29th September 2012, 03:46 PM   #21
If I remember correctly Zaph was pretty disparaging regarding Morel drivers and others using a similar design and has the measurements to back it up.
Yep, here are his comments about the MW166:
"Comments: The response is smooth enough to work with, but this driver is plagued by highish tall order distortion through the midrange. It has a huge voice coil (3") but a tiny spider supporting it. I don't recommend this driver as it's non-linear distortion of all types is pretty obvious with most music. Tested October 2005."
Old 29th September 2012, 04:14 PM   #22
wintermute's Avatar
Yes he was also pretty disparaging regarding the MW144. His an My measurements were VERY different. see here --> Morel MW144 deceitful specs and the following posts where zaph replies. my swept sine measurements do show relatively high distortion between 500 and 1000Hz (from memory), but I don't notice it
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 29th September 2012, 04:25 PM   #23
ingvar ahlberg's Avatar
I prefer first order x-overs in speakers for domestic use, imo they sound better and i belive in having as little as possible in the signal chain.
The Oy speakers have this x-over today:
Ingvar
Old 29th September 2012, 04:26 PM   #24
Did I miss them or were there no distortion measurements in that thread?
Old 29th September 2012, 10:44 PM   #25
system7 is offline system7  United Kingdom
system7's Avatar
I did wonder about the crossover. I know what the simple coil and capacitor one sounds like. In fact it's rather coloured even if lively. Lynn Olson and Jeff Bagby comment they found such a setup unsatisfactory in their D'Appolito designs.
I'd think something better would be 1mH coil, 10uF and 3 ohm in series shunted across the bass. 3.3-4uF series and 0.4mH shunt on the treble. Plus 2 ohm/10 ohm wirewound attenuator on the tweeter. That would give the tweeter an easier time of it and lose some cone breakup. Good start point for adjustment by ear.
But it's up to you.
Best Regards from Steve in Portsmouth, UK.
Old 29th September 2012, 10:56 PM   #26
Originally Posted by system7 View Post
This is all VERY interesting, Ingvar! You'll just have to ignore sreten's usual negativity.
There is nothing negative in my opinions. I'm all for enthusiasm and all
against misrepresentation of facts or alleged "experience" versus calling
referring to driver tests as "hearsay", when clearly descriptions of a
persons "experience" is as near to real "hearsay" as it actually gets.
I don't know whats VERY interesting about it, given the paucity of details.
Its a very expensive MTM, built by someone who freely admits that he
has no real experience of building such speakers, so no real perspective.
Given that you could build this for a hell of a lot less :
My RS180 MTM Design
In pretty much the same cabinets, or a different box choice, with near
identical sensitivity, bass extension and SPL capability, the obvious
question is do the far the more expensive drivers deliver the goods ?
I don't think so, nothing negative about that, and the above designs
crossover is currently far more advanced than the conjecture here.
rgds, sreten.
Old 29th September 2012, 11:15 PM   #27
Rullknufs's Avatar
Send a message via Skype™ to Rullknufs
My RS180 MTM Design
rgds, sreten.
But they don't seem to go very low, so they would need a pair of subwoofers?
My audio and DIY blog: http://phimusic.blogspot.se/
Old 29th September 2012, 11:37 PM   #28
They go as low as the Morels in similar boxes.
rgds, sreten.
Old 29th September 2012, 11:43 PM   #29
I fail to see how a standard 2nd order xover has any more in the signal chain than a 1st order one.
As far as I see it the extra components are parallel to the drivers and as such not strictly in the signal chain.
Either way I never liked too much acoustical overlap between drivers and very much prefer 24dB active to any passive xover.
But that's just me…
Old 29th September 2012, 11:54 PM   #30
wolf_teeth's Avatar
[QUOTE=Charles Darwin;3184175]I fail to see how a standard 2nd order xover has any more in the signal chain than a 1st order one.
As far as I see it the extra components are parallel to the drivers and as such not strictly in the signal chain.[QUOTE]
Contrary to popular belief, all components in a circuit are in the signal chain.
Parallel or series no matter, all are in the signal path, especially since sound is AC.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Brute force in a small cabinet... moray james Subwoofers 5 27th September 2012 08:28 PM
Making a low distortion cathode follower preamp by brute force bigwill Solid State 0 12th May 2007 05:53 PM
help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er jarthel Tubes / Valves 9 30th May 2006 08:47 AM
Help on Brute force Ryssen Tubes / Valves 5 2nd May 2004 11:07 AM
Copyright ©1999-2017 diyAudio
