Trying to diagnose a couple of notches - diyAudio
Old 28th September 2012, 05:06 PM   #1
Default Trying to diagnose a couple of notches
Hi Guys,
I'm trying to diagnose the source of a couple of notches in the frequency response of a couple of beaten up speakers. I'm using these speakers as a learning tool for when I work on something more significant.
I made the following measurements on axis at 2m outdoors at aprox 86db average level using a radio shack 33-2050 meter and a set of meter corrections found on the net. Charting is courtesy of excel.
This is what the frequency response looks like:
The red line is the raw response and the black is a corrected response I managed using a basic digital 10 band graphic equalizer.
I've circled a couple of notches that make graphic eq style correction difficult.
Thinking the problem through the notches are at ~1600Hz and ~4kHz. If I convert these frequencies into distances we're looking at just over 7 inches and about 3 inches.
Looking at the speakers I found this:
and this
Can these notches be created by a cabinet edge protroding 1/4 inch from flush with the baffle? Am I barking up the wrong tree? Any suggestions on how I could verify this?
trans
Old 29th September 2012, 12:02 AM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
Put absorptive foam over the edges and see if the anomalies go away.
You might be better off using holmimpulse and the RCA output of your SPL meter.
edit: given the look of that tweeter it may not be making any noise below about 4kHz.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 29th September 2012, 12:42 AM   #3
tvrgeek is offline tvrgeek  United States
Don't worry about the notches as much as the humps. These may all be mostly baffle diffraction. Do near field measurements ( as close to the tweeter as you can get) and see what the response looks like.
Head over to True Audio and read the Olson papers .
How to diagnose an old receiver? EvilYoda Solid State 5 2nd June 2011 12:18 AM
cap couple or direct couple class A SE amp? AudioGeek Solid State 7 7th May 2005 07:16 PM
help me diagnose speaker-failure! WildCowboys Multi-Way 9 19th April 2005 02:06 AM
Quality pots with "notches" at 12 o clock? massappeal129 Parts 5 3rd April 2003 10:14 PM
Copyright 1999-2017 diyAudio
