OB Bass Excursion
OB Bass Excursion
Old 29th September 2012, 06:55 AM   #31
Murphys Law is offline Murphys Law  Australia
Banned
forget about the sub and just buy another pro5100, you will get better bang for your buck.
What makes a good speaker great is not low frequency response, it is transient response in the region of 40Hz to 200Hz. This is where a lot of music falls that is difficult on speakers. That is why I suggested dual gpa 416, not because they are cheaper, but because it will sound better.
Old 29th September 2012, 07:12 AM   #32
Silent Screamer is offline Silent Screamer  Australia
I already have another Pro 5100 here (I bought two at the same time) only problem is impedence. To run both of the same input I would need to run them at 2ohm or 8ohm. Only other option is to split the output and run it on the other channel of the amp at 4ohm.
I dont want to go putting the cart in front of the horse, I haven't even tried them in a baffle of any kind yet. So I could potentially get significant gains once I do that... kick up the woofer crossover by a few dB and we could be looking at a whole different ball game.
Old 29th September 2012, 07:24 AM   #33
Banned
Yeah. No rush. Take your time.
The woofers you have are very good. As soon as I saw "underhung" motor I knew they were going to be special.
GPA416 also uses underhung voice coils
Old 29th September 2012, 09:00 AM   #34
sfdoddsy is offline sfdoddsy  New Zealand
EQ it then run full range pink noise.
I have a pair of AE IB12s a side and they produce major cone movement when run full range. Roll them off at 40Hz and they barely move.
Old 29th September 2012, 11:17 AM   #35
Banned
Why can't you run your mids down to 200Hz?
Old 29th September 2012, 11:24 AM   #36
While on paper they look like they should do that, they sound thin down in those frequencies. The size of the cone is just too small. They may be ok in a sealed box to lend a hand but in free air its a different story.
Old 29th September 2012, 11:28 AM   #37
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Just trying to remove some guesswork from the discussion. This is a simulation of the Goldwood 18" driver in H frame as propagated by MJK:
The upper diagram is showing the driver excursion in mm. The Goldwood is very well behaved in how he limits itself below 30 Hz. Most other woofers excursion will literally go through the roof with some SPL near 20 Hz. It is always a very good idea to apply a steep high pass at 20 Hz to prevent a dipole woofer from exceeding its excursion limit.
www.dipolplus.de
Old 29th September 2012, 11:28 AM   #38
Banned
Once you have it eqd it won't sound thin.
I bet if you put it on a baffle 55cm wide it won't sound thin
Old 29th September 2012, 11:29 AM   #39
Banned
Old 29th September 2012, 11:33 AM   #40
Attachment 303902
Any chance you could please model the same thing with these driver specs? Has plenty of XMax as you can see...
OB Bass ExcursionHide this!Advertise here!
A bass-boost circuit for OB Roushon Multi-Way 40 5th October 2012 08:44 PM
OB bass with bass trap oon_the_kid Multi-Way 17 14th September 2012 01:23 AM
OB vs BR: driver excursion bvan Full Range 5 13th January 2009 08:20 PM
Big Bass Ob CLS Multi-Way 24 29th February 2008 01:27 AM
OB bass surprise bigwill Multi-Way 5 30th April 2007 11:24 PM
