Measurement Equipment
Old 27th September 2012, 06:55 AM   #11
xjr100 is offline xjr100  Europe
sometimesuk, take a look on this manual:
http://www.ijdata.com/justMLS%20manual.pdf
It is commercial software, but gives basics on how to measure drivers/speakers.
Calibtated microphone is very important - this tool is for sure must be reliable, as in process of designing you will have lot of listening tests and analysis comparing what you hear and what are the results.
I have 2 ECM8000, both calibrated, but calibration files differs in some freqs upto 3db! It is important, if you really want to get the result.
If it is for "time spending" then go for simple solution - SB Live24 USB from eBay for 10£ and WM61 capsule for 2£. WM61 is better to buy from reliable source, not from eBay, as there many fakes. Here is sample drawing how it could be: http://diy-audio.narod.ru/audio/mic/meas-mic.PNG
At least it will be tool for beginning, you can start learning how it works, and for fine-tuning maybe you will buy good calibrated microphone + soundcard for 500-700£
Old 27th September 2012, 10:32 AM   #12
bjarnetv is online now bjarnetv  Norway
since you live in europe, i can recommend the SOFSCI soundweeper kit.
it comes with a modified usb soundcard, cables and a calibrated mic.
quite reasonable as well
Old 27th September 2012, 11:25 AM   #13
sometimesuk is offline sometimesuk  United Kingdom
that Sofsci looks even better. Everything I need, and all the calibration etc is already done.
Think, I'll get that instead, rather than the hassel of ordering different bits and pieces.
Old 27th September 2012, 02:00 PM   #14
Good kit!
Old 27th September 2012, 09:02 PM   #15
Keriwena is offline Keriwena  United States
Here's a link to the REW software/forum mentioned on the SOFSCI page, there's a lot of advice there on setting things up.
REW Forum at Home Theater Forum and Systems - HomeTheaterShack.com
Myself, I use the Tascam USB mic preamp:
Tascam US-122MKII - USB 2.0 Computer Audio Interface US-122MKII
and a calibrated EMM-6 mic from Cross Spectrum:
Cross·Spectrum Labs - Sound | Vibration | Engineering
The Tascam is flat enough not to really need calibration, and the EMM-6 beats out the Behringer by a bit. Not sure what import duties might cost you.
I've also had good luck with the simpler HolmImpulse, but the REW software has more features.
HOLM Acoustics
Measurement EquipmentHide this!Advertise here!
Measurement equipment ? fatmarley Multi-Way 9 15th May 2011 08:25 PM
Speaker Building Software and Measurement Equipment, Soundeasy, Behringer, Ashly,Etc. sbrtoy Swap Meet 6 14th March 2011 04:22 AM
Your Equipment ! EdT Parts 3 27th December 2006 01:16 AM
Test & Measurement Equipment for DIY Designers dgardner Solid State 15 26th July 2005 03:24 PM
Does anyone saw this equipment before? Sunsun22 Parts 8 14th October 2004 07:41 AM
