Eminence Alpha 15" has bass in OB?
Old 28th September 2012, 02:15 PM   #21
Melo theory is offline Melo theory  United States
Melo theory's Avatar
Don't worry about the published graph, its been known for quite some time that its wrong.
That driver is flat to 40 Hz.
I don't know why they don't fix it, seeing how popular the alpha is.....
I LIKE YOU
Old 29th September 2012, 03:56 AM   #22
oon_the_kid is offline oon_the_kid  Malaysia
oon_the_kid's Avatar
I suspect that other people's measurements better reflect real life situation. My guess is that at 1watt. The speaker is clipping. See my previous post. After all at 1kHz it is almost 100db. Threhold of ear damage through long term exposure is 80db. So very likely most people would be listening and measuring it closer to 0.1watt or less. Without the speaker clipping, i reckon the graph would be flatter....
Oon
Old 18th May 2014, 02:24 PM   #23
renjiish is offline renjiish  India
The site below shows a better measurement.
Eminence Alpha 15A speaker. The Eminence Alpha 15A is a 15" 8 ohm speaker for all bass applications. Alpha-15A is a 200 watt RMS 15" woofer.
Old 20th May 2014, 06:49 AM   #24
CLS is online now CLS  Taiwan
The published sensitivity and response curve are useless when you use it on OB, so, let's just drop it.
Suggestions:
Use (or borrow) some other boxed speakers (subs) to play some bass rich music in your place as loud as you need, measure the SPL in LF.
I remember there's a spreadsheet or S/W for calcuating OB's LF SPL somewhere. Plug the cone area and Xmax into that calcuator to see if it fullfill your requirement.
Alpha 15 has only 3.x mm Xmax, which is small. So I'm afraid it's not capable of doing loud and low at the same time on OB. Probably very limited SPL under 40Hz. Whether it's enough or not is up to you.
Old 20th May 2014, 01:34 PM   #25
DeonC is offline DeonC  South Africa
DeonC's Avatar
Here is what the predicted response is according to Thorsten Loesch's excellent XLBaffle spreadsheet. The parameters and conditions is seen in the first pic.
In room response:
In room power response:
Deon
PS. Low-end power response is limited because I used X-Max and not X-Mech in the calculations.
I don't suffer from insanity. I enjoy every minute of it.
Have a look at my favorite thread: Interesting YouTube video clips
Old 20th May 2014, 02:15 PM   #26
adason is offline adason  United States
adason's Avatar
some interesting info about OB11 project of Troels Gravesen can be found here:
OBL11
He provides measurements directly on open baffle for Alpha 15A and DeltaLites, which he likes better on ob
Old 21st May 2014, 05:21 AM   #27
That'd be more practical because when it goes beyond Xmax, the distortion will be skyrocketing.
Louder, yes; better, no.
Eminence Alpha 15" has bass in OB?Hide this!Advertise here!
OB consisting on 2 Eminence Alpha 15"s and B&G Radia RDxx OB Fan Multi-Way 22 9th September 2012 03:16 AM
Opinions on Eminence Alpha a 15" mayhem13 Multi-Way 12 30th November 2011 12:28 PM
FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 nl Swap Meet 2 10th June 2009 10:15 PM
For sale: New pair of Eminence Alpha 15" (Australia) gainphile Swap Meet 4 26th February 2009 09:54 PM
DX2 & Eminence 15" OB britbug Full Range 17 9th May 2008 07:29 PM
Copyright ©1999-2017 diyAudio
