And Now For Something REALLY BIG - Page 80 - diyAudio
Old 17th January 2013, 12:42 PM   #791
sippy is offline sippy  United Kingdom
Make sure you have an adult to supervise you JKRO. :P
Old 17th January 2013, 12:56 PM   #792
JRKO's Avatar
Send a message via AIM to JRKO
Adult supervision? check
sticky-back-plastic? check
Janet Ellis, Simon Groom & Peter Duncan? I wish
So for both card & paper I will cut complete sides and build up from there, having secured then into a horn.......hopefully anyway
If I'm not making noise, I'm making something to make noise
Old 17th January 2013, 12:59 PM   #793
Ahhh, the memories.......
Old 18th January 2013, 12:34 AM   #794
JRKO's Avatar
Quick miniDSP question. I think the 2 way xover advanced looks better with PEQ, LPF & HPF available simultaneously, 48dB filters slopes & REW integration
Is that the preferred option?
James
Old 18th January 2013, 12:10 PM   #795
IG81 is offline IG81  Canada
IG81's Avatar
James
That's what I use, works quite well. I don't use the REW though. If you run out of filters - throw your drivers in the can and start over!
IG
Old 18th January 2013, 12:35 PM   #796
JRKO's Avatar
Thats good enough for me IG!
another silly question about wiring up a pot for my ACA HF amp. I'm looking at this page Stereo Volume Controls and this piccy......is that correct? does the left input go to the right output in
i thought
1 input L
2 output L
3 gnd
4 input R
5 output R
6 gnd
Old 18th January 2013, 01:07 PM   #797
palmas is offline palmas  Portugal
i thought
1 input L
2 output L
3 gnd
4 input R
5 output R
6 gnd
You're correct!
Old 18th January 2013, 01:20 PM   #798
JRKO's Avatar
cheers palmas
you know when you just not sure if you're mad or the diagram is........
BTW disappointment on the papier mache front. I just cant get ANYWHERE near accurate enough to make even the template.
I need a laser cut metal template me thinks
Old 18th January 2013, 01:47 PM   #799
If you go the metal way you could try and paint them inside and out with damp proof membrane from your local builders supply store.
It's a bitumous, water-based rubber compound and should help to reduce any potential ringing.
Old 18th January 2013, 03:27 PM   #800
JRKO's Avatar
Back to the volume control.
1 input L
2 output L
3 gnd
4 input R
5 output R
6 gnd
but gnd come from a ring on the jack. does that go to leg 3 and then on to the gnd on the amp board? have it connected straight and vol is max allways
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 02:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 03:53 AM
Copyright 1999-2017 diyAudio
