#741 | ||
Captain America: 'Doc... I think now is the perfect time for you to get angry' Bruce Banner/The Hulk: 'That's my secret Cap, I'm always angry' Tnx guys. Looney Tunes Rage Monster has left the building. Let 'normal' lunacy commence!! I see paper cuts in my immediate future
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home |
#743 |
Sweeeet!
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#744 |
Good to see you back JKRO
![]() Make that paper cuts filled with wall paper paste - my movements on this have been minimal since adding very carefully weighted out quantities of pluff to my 12lta's. Time to bribe carpenter to make me my horn jig I guess....... |
#745 | |
And as they can cut down to 0.5mm steel/copper/stainless/brass sheet, I might get a price for a genuine one off, all metal, silver soldered or brazed multicell kit
#746 |
Ok, so its not progress in the way I was hoping but I've ordered my miniDSP so at least I'll be able play 'once I get some damn horns built'
I have new tablets without sedation so up all hours and very unfocused again. One of the side effects listed with the med? Sudden death!!! I kid you not. What the hell is the world coming to when a side effect of a med for MANIC DEPRESSION is sudden death? Next step, clear the table to start work
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home Last edited by JRKO; 11th January 2013 at 12:39 AM. |
#747 |
On a side note. How do I match the volume of the horn with the bass? The horn will be 109dB/W/m and the bass around 98dB/W/m - thats nearly 4 times as loud.
Do I use the master vols inside the miniDSP? Should I reduce the highs alone, or reduce the highs AND raise the bass? Any wisdom from hi efficiency horn loving lunatics appreciated ![]() I was hoping to use my ACA 5w SE Nelson Pass midget wonder to drive the high end and a hifimediy 180wpc for the bass - how does that look?
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home Last edited by JRKO; 11th January 2013 at 12:41 AM. |
#748 |
I am watching with mini dsp ready and waiting. Sorry to hear about the meds. That sucks.
#749 |
Lower the gain on the horn amp. If it does not have a volume control, install one. I also suggest an L-Pad on the horns. For 8 ohm horn drivers try 4R in series, 8R parallel to the driver. That will bring them down 6dB and may be an easier load for your amp to drive.
Take the Speaker Voltage Test! |
#750 |
Hey Pano - Could that not be done digitally inside the miniDSP? or would lpads still be a good idea
I've ordered the 'dsp volume control and will play between running that full and using the preamp control or using the preamp only or using the 'dsp control only
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home Last edited by JRKO; 11th January 2013 at 02:45 AM. |
| Transformers: How big is TO big?? | dfdye | Power Supplies | 39 | 4th September 2010 02:30 PM |
| Big Toroids & Big Caps | K-amps | Swap Meet | 10 | 25th June 2009 07:43 PM |
| Having problems with port size... how big is far too big? | fjhuerta | Multi-Way | 10 | 30th August 2005 06:20 PM |
| Big Big hum ??? | vlljpior | Tubes / Valves | 4 | 26th August 2005 03:53 AM |
