And Now For Something REALLY BIG - Page 68 - diyAudio
Old 24th November 2012, 03:17 AM   #671
GM is offline GM  United States
GM's Avatar
Originally Posted by JRKO View Post
Does axial length mean the distance between centres, from throat to mouth? Is it throat area that I then need then to calculate the flare?
Correct. I found my old expo spreadsheet, so post the mouth, throat, axial length of the various horns or input them into HR or similar.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 24th November 2012, 03:27 AM   #672
GM's Avatar
Originally Posted by Kindhornman View Post
There are many other ways that the shape change can happen and inner and outer cells can be different in cross-sectional change while the overall expansion rate of combined cell area is identical for the final cutoff frequency.
Absolutely! Back in the '60s I designed slot car parts for awhile and we had this huge, old plastic molding machine, but for all its size it couldn't make parts much bigger than a motor end bell, but I had audio wet dreams about a house size one that could mold massive multi-cells made from Delrin with 64 or more cells starting with ~0.2" diameter throats.
GM
Old 24th November 2012, 03:53 AM   #673
Kindhornman's Avatar
GM,
What is your idea behind so many cells? How wide a dispersion pattern are you trying to produce?
Slot cars now that is going back. I had some myself and went to my local track to run the cars. I'm curious why you would think to use Delron for a horn lens, wouldn't be my first choice for a material. And attaching the multiple cells together would be a real bear. It isn't a very stiff material but is high density for a plastic.
Old 24th November 2012, 09:01 AM   #674
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by GM View Post
... so post the mouth, throat, axial length of the various horns ...
1005:
  • Axial length =15.5"
  • Mouth = 6.25" wide, 4 sides
  • Throat = unknown, but between 0.75" and 1"
Take the Speaker Voltage Test!
Old 24th November 2012, 10:31 AM   #675
JRKO's Avatar
Send a message via AIM to JRKO
Thanks for the additional info fellas.
Can anyone point me to a user guide for Hornresp?
If I'm not making noise, I'm making something to make noise
Old 24th November 2012, 12:15 PM   #676
The best hornresp guide is hornresp's built-in help file, IMO
Old 24th November 2012, 12:24 PM   #677
JRKO's Avatar
D'oh
Old 24th November 2012, 03:31 PM   #678
GM's Avatar
Originally Posted by Pano View Post
1005:
x = axial length distance from throat where area doubles.
0.75" square throat:
length 15.496
multiplier 6.117
length (x) 2.533
k 0.274
Am 39.063
At 0.563
Fc 295.00
SoS 13,548.00
1" square throat:
length 15.498
multiplier 5.288
length (x) 2.931
k 0.237
Am 39.063
At 1.000
Fc 255.00
SoS 13,548.00
I just found out that converting/inputting the areas and length into HR displays Fc in the F12 window [though insignificantly different due to conversion, different SoS than the one Altec listed] and allows one to choose axial length 'x' when exporting the design data, saving one from oddball fractions, so seems the easiest way overall to get all the layout particulars.
GM
Old 24th November 2012, 05:04 PM   #679
GM's Avatar
Hopefully improving a multi-cell’s overall performance and particularly its HF response over existing designs.
??? Wasn't trying for any particular polar response per se, just that starting with a smaller throat yields a smaller mouth for a given axial length, so it takes more cells to get ~ the same polar response, throat, mouth area as an 1803/whatever.
Again, it was just a 'pipe' dream of a ~20 yr old whose manufacturing, materials knowledge was pretty much limited to what he had learned to that point from hot rodding motorcycles, cars along with a several year stint working in an intense design engineering environment that covered architectural, structural, mechanical and topography, which taught him enough to help design all aspects of slot car parts/assembly; so naturally he would have fantasized a horn molded as a single piece [not individual parts] using a material he had some ‘hands on’ knowledge of.
Delrin had already been proven a suitable material for injection molding of motor end bells and spur gears due to its damping ability over a wide HF BW while maintaining sufficient rigidity, heat resistance at a low weight and didn’t audibly ‘ring’ in my rather crude testing, so seemed a good enough material.
I guess I could have gone 'over the top' by fantasizing using Bakelite, though being just a ‘pipe' dream, I didn't waste my time giving any real thought to any design details as it seemed much too far-fetched/expensive a venture in my rather creatively challenged mind to ever become a reality.
Since this is apparently more your area of expertise, what material would you have specified circa 1967 [and today] for a one piece molding of a multi-cell to cover the 300-20+ kHz BW?
GM
Old 24th November 2012, 07:02 PM   #680
JRKO's Avatar
Why oh why am I so freaking stoopid?!
GM I thank you in blind faith for the post below on the two throat variations. Unfortunatly I'm an idiot and despite looking thru the HR help section I dont get most of the info you've posted.
I'll have a glass of wine and then try using HR itself to see if I can make it squawk
James
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 03:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 08:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 07:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 04:53 AM
Copyright ©1999-2017 diyAudio
