And Now For Something REALLY BIG - Page 59 - diyAudio
Old 16th November 2012, 11:11 PM   #581
GM is offline GM  United States
GM's Avatar
Originally Posted by JRKO View Post
is the 632hx the cut off for this multicell so I should crossover higher, say 750hz?
No, I just SWAG'd what the lowest practical XO point might be based on its size Vs a smaller and larger multi-cell I'm familiar with.
Without specific dims including the throat adapter, no way to calculate the absolute lowest, but for sure it should handle a 750 Hz XO/2nd order.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 16th November 2012, 11:15 PM   #582
GM's Avatar
Just to clarify, do you mean small end or the large end of the cells are not as sharp?
The throats [small end]. The WE/Lansing/Altec multi-cell throats I've seen were honed to a near knife edge, something not practical to do with wood unless it's very hard, which of course might crack over time, so not practical.
GM
Old 20th November 2012, 10:53 AM   #583
JRKO's Avatar
Send a message via AIM to JRKO
I think I'll see if the guy can make a pair but get the joint between throat terminations thinner.
Will the increased throat size then become an issue?
If I'm not making noise, I'm making something to make noise
Old 20th November 2012, 09:37 PM   #584
GM's Avatar
In theory.......
GM
Old 21st November 2012, 07:29 AM   #585
JRKO's Avatar
which can be negated if he sands the outside of the throat rather then the inside - man my brain is slow to spot the obvious sometimes
Old 21st November 2012, 07:49 AM   #586
JRKO's Avatar
How would one go about building a horn like this, where none of the curves are cut from 6" of solid wood with a router?
do you make up shaping blocks and laminate wood or other onto them layer my layer?
Old 21st November 2012, 09:47 AM   #587
buzzforb's Avatar
build a skeleton and clamp thin ply in multiple layers to it....or have a giant steam box and put normal play in and then bend it. I believe he used a circular rasp or sandpaper on a stick to shape the throat. JMLC says the throat is the most important part in terms o distortion caused by reflections.
...Shape the sound , Man!
Old 21st November 2012, 11:11 AM   #588
buzzforb's Avatar
Like this.
Exponential Midrange 2
Old 21st November 2012, 11:22 AM   #589
There is flexible ply available:
Lathams Ltd - Flexible Plywood
Old 21st November 2012, 11:44 AM   #590
JRKO's Avatar
Wow thats some construction there buzzforb. Maybe with the wacky board Charles Darwin just linked to, the hardest part (bending the wood) could be easy?
Also thinking of trying to make a multicell.........
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 02:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 03:53 AM
Copyright 1999-2017 diyAudio
