#561 |
Isn't electronic delay going to only make the time alignment work directly on-axis (or wherever you choose to figure it from) and get progressively out of whack further off axis?
#562 |
I've never actually used digital TD or read anything about its design or have time ATM to research it, just know that folks are pleased with its performance even with horn-in-horn systems. I mean all it does is move one sound system back in time to match another, so don't see why it would change the summed off axis response from one done physically.
Maybe this will help: Live Sound International | Tech Talk: How to correctly get loudspeaker drivers in sync GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#563 |
Owner and operator of irc.tenettenba.info
any options for these woofers and the ownership of cats? ie, wire/steel speaker protectors this large? 18" or larger?
Yep: http://www.ebay.com.au/itm/2X-18-Met...item484699ce1b
#564 | |
10.63/2 = 5.32*0.613 = 8.7" Is this inches from the cabinet below or the driver edge?
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home Last edited by JRKO; 16th November 2012 at 09:17 AM. |
#565 |
What cat do you have? A very angry main coon
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home |
#566 | |
From the cab to bottom of the mouth. Note the relatively large gaps: http://www.lansingheritage.org/image...pro/page04.jpg GM
#567 |
I don't have one at the moment but I am planning on getting one sometime soon
![]() It has to be white though, I love white cats, if you have any suggestions I'd be greatful for them. The one I had 10 years ago was a feral/hybrid, we're not entirely sure what breed he was. At the moment I've got a 12" driver that needs protecting, better get a speaker cover... will probably be getting a second 12", I just like the accuracy of 12" drivers with the right cone material, its weird.
#568 |
I have a ragdoll. Unbelievably friendly, will follow you round the house and listen to music with you. Indoor cat only though.
#569 |
D'OH!!!!! Curse my Mac keyboard!!! I divided instead
![]() yes its 3.26"
#570 |
THe A8 in that pic looks liek a an MLTL. THat would definitely fit the big bill.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
| Transformers: How big is TO big?? | dfdye | Power Supplies | 39 | 4th September 2010 02:30 PM |
| Big Toroids & Big Caps | K-amps | Swap Meet | 10 | 25th June 2009 07:43 PM |
| Having problems with port size... how big is far too big? | fjhuerta | Multi-Way | 10 | 30th August 2005 06:20 PM |
| Big Big hum ??? | vlljpior | Tubes / Valves | 4 | 26th August 2005 03:53 AM |
