And Now For Something REALLY BIG - Page 55 - diyAudio
Old 14th November 2012, 03:17 PM   #541
buzzforb's Avatar
Need pics of audio porn. What horn are you trying to begin with?
...Shape the sound , Man!
Old 14th November 2012, 04:22 PM   #542
JRKO's Avatar
Send a message via AIM to JRKO
Audio porn as requested the annular phase plug is funky
A for the horn I'm really not sure. I can get a pair of 8 cell (50cm x 27cm) for 180, The Faital Pro plastic job for 80 a pair, a pair of 400hz Tractrix Horn for 160, or the full JMLC-400 for 380 a pair.
The Faital Pro horns kinda seem a waste of 80, if for just over twice the price I get the multicellular horns. The 8 would be a cool place to start and are good value from what I can see.
decisions decisions.........either way I get the horn
If I'm not making noise, I'm making something to make noise
Old 14th November 2012, 06:00 PM   #543
buzzforb's Avatar
Is that 180 delivered, for the multicll. If so, that sounds great.
Old 14th November 2012, 06:08 PM   #544
JRKO's Avatar
200 including delivery - still a steal me thinks and not a bad start.
Old 14th November 2012, 06:11 PM   #545
buzzforb's Avatar
I would happily try it for that kind of coin, especially when the real thing will set you back well over a thousand dollars, before shipping.Cool phase plug on the Faital.I have noticed that some of the JBL horns compress the entry of the horn, getting smaller before expanding agin. Kinda like the mouthpiece of a real horn. It looks like this phase plug is doing something similar.
Old 14th November 2012, 06:17 PM   #546
JRKO's Avatar
It appears to focus the sound into the mouth - i think
Any Altec multicell would kill me financially. 200 or $320 is a steal. I just need to figure out how to finish them. Nude MDF wont make the grade at home for long
Old 14th November 2012, 06:23 PM   #547
buzzforb's Avatar
MDF is the a wonderful choice when you want a beautifully smooth, painted finish. Many furniture folks use it over wood for this very reason. wood will sho grain,even when perfectly sanded. I know someone who can tell me exact method for doing so and I can attest to the quality of their products. Ill let you know, if you are interested.
Dont know about the phase plug, but the jbl horns are done that way for loading, I believe. I wonder if Faital just chose to do it internally.
Old 14th November 2012, 06:42 PM   #548
Pano is offline Pano  United States
Pano's Avatar
Well, you know me, I'd choose the multi-cell horns.
I think there are some good threads in the construction section about smooth finished on MDF. If not, Mr. Google should find you some.
Old 14th November 2012, 07:16 PM   #549
JRKO's Avatar
I am leaning that way Pano!
It wasn't so much the finish on the plain MDF as painting the throats etc and the polyester foam filler.
I found a guy who says make up a jig to support the cell uptight with the mouth mount on at the bottom. Paint inside the cells fairly liberally and excess paint will drip thru the mouth and into a paint pot underneath.
As for the polyester foam I guess I could cover it in multiple layers of paper and then paint, or maybe a cheap veneer then paint. I've seen some of these horns with cork over the sides that looks ok
what thinks you?
Old 14th November 2012, 07:23 PM   #550
Pano's Avatar
Hmmmm.... not sure, as I am no woodworker at all! The tar filled horns had a tin skin over then, so appeared solid. I guess you could do the same with very thin plywood, veneer or even wall paper. Could give it a nice uniform look without too much trouble.
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 02:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 03:53 AM
Copyright 1999-2017 diyAudio
