And Now For Something REALLY BIG - Page 54 - diyAudio
Old 8th November 2012, 10:50 PM   #531
buzzforb's Avatar
Just brought it uo for cost considetation, as DACs are not cheap.
...Shape the sound , Man!
Old 8th November 2012, 10:57 PM   #532
JRKO's Avatar
Send a message via AIM to JRKO
some are.......DAC eBay
I'll probably start with the minidsp and see where I'm headed from there. Look at me!! I haven't even got a pair of horns yet!!!!
If I'm not making noise, I'm making something to make noise
Old 9th November 2012, 01:59 PM   #533
JRKO's Avatar
Happy days!!! Drivers ordered and I managed to save some pennies along the way.
Bluearan 191 per driver
Lean Business 144 per driver
saving me 94
Thats enough for a minidsp
Old 9th November 2012, 02:55 PM   #534
As for DACs I use an Echo Audio AF12 (12 channel AD-DA, 24dB 192kHz) which cost me 350 new.
In blind tests it is equal to Apogees Rosetta which is 1500 for a 2 channel unit.
Old 10th November 2012, 06:56 PM   #535
JRKO's Avatar
Would the volume control in a B1 be enough feeding the minidsp?
Ok I just found out the ADC is ok but the volume control onboard the minidsp is lossy Whats the point in digitising a signal and then offering only part of it back unless you play at full volume?????? Who wants most of their music signal??? I might not fully understand the whole bit depth sample rate malarky but less is less. I listen at lower levels, so most of the time I'll be getting less info than a standard 16bit CD thru a standard system With a compression driver and high effeciancy 15" driver circa 96dB\W\m I cant very well play full blast. I know I can try it an see how it sounds but I'll always know there is more info in there I'm not being allowed to listen to.
If the B1 pre volume control is the best solution this means I'll need a volume control after the minidsp - for 4 channels
Old 11th November 2012, 08:11 AM   #536
buzzforb's Avatar
Why not use B1 before mini.
Old 11th November 2012, 09:22 AM   #537
Pano is offline Pano  United States
Pano's Avatar
Not all digital volume controls are created equal. If you are running at 24 bits or higher, it really does no harm. There are software players that do volume control in floating 32 or 64 bit, then bring the stream out in 32, 24 or 16 bit as you choose. I've done listening tests and measurements galore, and can't find that it does anything but lower the S/N ratio. Analog volume controls do that too, in a different way.
If you are afraid of losing bits, then you really shouldn't use a digital crossover/EQ. How do you think they generate the crossover slopes and EQs?
You do want to get your gain structure right before you start doing volume control. Usually your power amps will have far more gain than you need.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 11th November 2012, 10:17 AM   #538
fas42 is offline fas42  Australia
Banned
I have never found that digital volume controls, properly integrated into the overall gain structure, ever degrade the sound. On the other hand, analogue volume controls are something I have deep suspicion of, once you become sensitive to the signature distortion of the conventional setup then you steer well clear of them ...
Frank
Old 11th November 2012, 12:54 PM   #539
JRKO's Avatar
If the remaining signal, whatever its sample rate and bit depth is then top skimmed again (and variably at that) couldn't you in theory end up with an 8bit/48khz signal being amplified?
Ah, who knows. I've got to deal with it at the moment as I have a snowballs chance in hell of sorting a passive filter, especially as I'll be using the CD's with the Emken before I get the midbass drivers in. Of the two options which is better? B1 fed - volume - minidsp - amps, or Signals - minidsp - volume - amps? I guess I can try both with a B1 volume control at max and use the minidsp vol or minidsp at max use the B1 control.
I found your gain structure article Pano - good read. I saw it come up in the active vs passive thread (which I think comes down to ease of design/construction/use) as well as a potential pitfall
Now I have to read about the B1 options!!
Old 14th November 2012, 02:25 PM   #540
JRKO's Avatar
The HF144's have arrived. Thats part 1 of 3.
next horns & minidsp
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 02:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 03:53 AM
Copyright 1999-2017 diyAudio
