And Now For Something REALLY BIG - Page 49 - diyAudio
Old 27th October 2012, 10:18 PM   #481
buzzforb's Avatar
Thank you for the correction. They are indeed sectoral.
...Shape the sound , Man!
Old 27th October 2012, 10:57 PM   #482
JRKO's Avatar
Send a message via AIM to JRKO
Originally Posted by buzzforb View Post
Consider though, a light cone and a strong magnet
From reading that Adire paper thread I linked to earlier "Transient response is NOT acceleration; rather, it is the rate of change of acceleration (defined at the jerk force, measured in units of Stapps). Acceleration is SPL - the higher your acceleration, the louder you are.................Anyway, in a driver what limits how fast you can change your acceleration (rate of change of acceleration is the jerk force) is the inductance. That's what limits your transient response. Mass really has nothing to do with transient response. Only efficiency...................Efficiency is affected via mass changes, but transient response is not"
Originally Posted by Pano View Post
More cells = more better, in my book. At least for typical domestic listening.
Given the choice between multi-cell and "One Hole" horns, I've made my choice.
so 15 would be better than 8?
Pano, please san I ask for your reasoning (in detail if pos.) why you feel/think that way and made that choice. I very much respect your opinion & knowledge
If I'm not making noise, I'm making something to make noise
Old 27th October 2012, 11:05 PM   #483
buzzforb's Avatar
Then you should get the TD15m. It has light cone, high efficiecny, and Le better than any others @.2mH. That is 25% of most others you have looked at or talked about. It also has light cone.
Old 27th October 2012, 11:11 PM   #484
JRKO's Avatar
holy cow 0.2mH? It'd kill you if you just thought about music, let alone play it!!
Old 28th October 2012, 01:51 AM   #485
Pano is offline Pano  United States
Pano's Avatar
I think more cells = better because that's what I've heard. Not what someone told me, what I've really heard. I've heard the multis from 2 to 18 cells. More always seemed better to me. Bigger, more open, more real. That said, the 1005 and 1505 may be the practical limits for home use.
Take the Speaker Voltage Test!
Old 28th October 2012, 01:33 PM   #486
JRKO's Avatar
As for placement/aim of the multicellular horn - do you fire them straight forwards, down the room? Or toe the in so the centre is aimed at the listener?
Old 28th October 2012, 04:09 PM   #487
Pano's Avatar
Both work - it may be room dependent. Currently mine are pointed straight at me. That could change in a different room.
Old 29th October 2012, 06:47 PM   #488
JRKO's Avatar
Thanks Pano. I've asked the ebay guy about the cell terminations and I'l let you know what he says. Here's a pic the maker sent me of an 18 cell version.
Old 29th October 2012, 07:17 PM   #489
JRKO's Avatar
Wow he was quick!!
"Because of the widening of the of the entrance it keeps all the 15 appertures the same area never thought about it before. they could be tapered if you prefer that would give the outside 6 cell slightly more area"
I guess he means widening at the external cells. I think its because his cells start from a flat plane rather than radiating out, as if from a central point.
What thinks you?
Old 29th October 2012, 08:12 PM   #490
JRKO's Avatar
Just thinking on the above, doesn't that mean the outside are a different length to the rest?
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 03:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 08:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 07:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 04:53 AM
Copyright 1999-2017 diyAudio
