And Now For Something REALLY BIG - Page 48 - diyAudio
Old 27th October 2012, 12:56 PM   #471
Josephjcole's Avatar
Have you looked at the 15PR400? Lower le, lower mms, would probably need a larger enclosure, but other wise the specs look better to me than the FP 15FH510
Old 27th October 2012, 01:28 PM   #472
buzzforb's Avatar
Ultimately, you trade size for extension.
...Shape the sound , Man!
Old 27th October 2012, 01:54 PM   #473
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
and very short Xmax 2-3mm Xmax(one way)
but yeah, could have been a good one
tho, with a tube flea amp, I doubt it will ever get into trouble
but hook it up with a 200watt....big bang
Old 27th October 2012, 04:38 PM   #474
JRKO's Avatar
Send a message via AIM to JRKO
As far as I can see mass of cone is not really that important, rather the magnets motive power & strength. A light cone with rubbish magnet is worse than a cone 3 times the weight with a great motor. I guess its a power to weight ratio type thing?
interesting read here Adire Audio tech paper on transient response with input from Dan Wiggins of Adire Audio. I cant find the paper unfortunately
If I'm not making noise, I'm making something to make noise
Old 27th October 2012, 04:57 PM   #475
buzzforb's Avatar
Without doubt. Consider though, a light cone and a strong magnet. The Faitals and Beyma drivers look best from current selection. I would of course inlcude the AE drivers in there as well.
Old 27th October 2012, 08:29 PM   #476
Pano is online now Pano  United States
Pano's Avatar
Originally Posted by JRKO View Post
For the multicell's is it more cells for nearer listening as thy tend to have a wider spread, smaller horn. for example would I be better off with the 15cell version than the 8cell in my room? they seem to have identical cell mouth sizes......
More cells = more better, in my book. At least for typical domestic listening.
Given the choice between multi-cell and "One Hole" horns, I've made my choice.
haha just found this little item. Makes my plans, um, diddy
That's a classic, love it. Laugh if you will, but a buddy of mine showed me photos of a house in Crete he visited that was just about that bad. All horns, with the bass horns extending way out into the garden. Crazy inside, with the giant horn mouths.
Somewhat more restrained is this famous system.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 27th October 2012, 08:30 PM   #477
buzzforb's Avatar
Pano,
Would you expect somewhat similar performance from the wooden iwata forns with fins in the mouth?
Old 27th October 2012, 08:32 PM   #478
Pano's Avatar
Somewhat similar is kinda vague.
Old 27th October 2012, 08:49 PM   #479
buzzforb's Avatar
Well I was thinking that the theory of operatin should be the same. Basically an attempt to prevent beaming of HF signal, intentitonally creating HF lobing.
Old 27th October 2012, 08:52 PM   #480
Pano's Avatar
Sectionals don't work as well, IMO. They aren't terrible, tho, unless badly built.
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 02:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 03:53 AM
Copyright 1999-2017 diyAudio
