Old 22nd October 2012, 08:33 AM   #411
JRKO's Avatar
Send a message via AIM to JRKO
A penny for your thoughts on passive/active for CD tinitus
what of PLLXO?
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home
Old 22nd October 2012, 08:51 AM   #412
tinitus is online now tinitus  Europe
Originally Posted by JRKO View Post
A penny for your thoughts ....
impedance interfere with passive xo, and changes its function and resulting response, phase etc
and compression driver/horn combo is even worse, with multiple impedance ressonance peak
active is at least free of those speaker impedance issues
still have to deal with acoustic response tho
I guess those problems might have made the CD's bad reputation of sounding very harsh much worse than it deserves
and no doubt it will sound unbareably harsh if the xo is not functioning properly
on the good side, I don't think you need any fancy amplification for a CD
probably a simple low power chip amp will do fine, and be very simple
the remaining other drivers might still work with relatively simple passive xo
Old 22nd October 2012, 09:06 AM   #413
JRKO's Avatar
tnx tinitus.
So the passive crossover is passive in both directions - subject to the drivers impedance anomalies - just because it is designed to give the correct crossover freq. & slope , it may not due to the driver attached.
An active crossover is essentially line level (before amplifier) and not subject to driver feedback, stamping its exact filter upon the signal before amplification with no speaker level interaction.
This should also be true of a PLLXO?
Old 22nd October 2012, 03:05 PM   #414
IG81 is offline IG81  Canada
IG81's Avatar
tnx tinitus.
Yep, this is the case AFAICT. I've tried both PLLXO and active via mini-DSP and it's much better than passive speaker-level Xover, at least at my design skill level.
IG
Old 22nd October 2012, 04:28 PM   #415
JRKO's Avatar
which is no doubt many levels above mine!!
Old 22nd October 2012, 06:17 PM   #416
buzzforb's Avatar
Little update on my project. Decided to get some Altec 416's. Got them used for a good price. Also got some Altec 288 compression drivers. That leaves just the horn profile. I will begin my build in a couple of weeks, so hope to have some more extensive impressions soon
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 22nd October 2012, 09:39 PM   #417
JRKO's Avatar
Altec all the way buzzforb?
The 288 is a 1.4 incher if I remember correctly. I read (http://alteclansingunofficial.nlenet...ers/TL_231.pdf) that the 288 starts really dropping of around 15k.
Response graph shows big drop. Are you going to prop it up with a s/tweeter or EQ the hell out of it?
be interested to see you construction of the iwata!
Old 22nd October 2012, 10:21 PM   #418
buzzforb's Avatar
Depends. I will probably allow for super tweet or small horn in design. May not need it. Prefer as little EQ as possible, but will do what is necessary. Here is my thread if you want to drop in. Ill stop polluting yours. Hurry up and get something. Its a build off!
Be forewarned. Lots of screwing around
Horn/TL combo
Old 22nd October 2012, 10:33 PM   #419
Pano is offline Pano  United States
Pano's Avatar
I don't try to force my Altec 288s much past 6K. I use bullet tweeters above that. They go out to about 17K-18K.
Old 22nd October 2012, 10:42 PM   #420
Speakerholic
Cal Weldon's Avatar
I have had success with the 288 up to 10k with a super taking over from there. Wait are we still talking buzzforb's stuff here?
Someone should call a moderator for all this OT stuff.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 02:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 03:53 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
