#371 |
If i go with 1", it will be 10hk or rk as they go lower. Have to watch resonant frequwncies
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#372 |
my HF100 is the old one
from memory its more like the HF102, a bit round and rolled off the new revised model should be able to go lower but maybe the low ressonance peak is lowest possible xo point but I dont know hmm, right now its a 6.8uf cap looking into 15ohm series resitor, then some inductors and resitors in paralel, and a very small series inductor looking into a small resistor its probably not crossed very low, maybe just below 2khz, like maybe 1.7khz, but I really dont know that said, I did put a lot of work into making the throat transistion smooth as possible CD exit angle ? I dont see there could be much to do about it |
#373 |
I just want to hear the polymer diaphram. It sounds like it has the potential to maintain clarity, but be smoother like BE diaphram is said to do.
#375 |
Pano, what about the hf 144? This was what i was leaning to.
#376 |
I prefer to x-over a bit higher, think it sounds better when the lf unit covers the fundamentals in voices, but thatīs just an opinion.
If You can accept 1.7kHz or up a bit then the STH tractrix horn is really nice, very well built and cheap.
Ingvar |
#377 |
Is that the 104?
#378 |
Ingvar |
#379 |
HAHAHAHAHA!! The local rep for Auto-Tech is a 20 min drive from me. Am trying to arrange demo. Will take pix if allowed and feedback next week
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home |
#380 |
Seeing him monday!
heres some pix I found to wet the appetite To me the first pic of the E-JMLC-300 looks like a triffid that might swallow you whole if you talk while its playing! Im liking the JMLC-400.........
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home Last edited by JRKO; 12th October 2012 at 06:55 PM. |
| Transformers: How big is TO big?? | dfdye | Power Supplies | 39 | 4th September 2010 02:30 PM |
| Big Toroids & Big Caps | K-amps | Swap Meet | 10 | 25th June 2009 07:43 PM |
| Having problems with port size... how big is far too big? | fjhuerta | Multi-Way | 10 | 30th August 2005 06:20 PM |
| Big Big hum ??? | vlljpior | Tubes / Valves | 4 | 26th August 2005 03:53 AM |
