And Now For Something REALLY BIG - Page 34 - diyAudio
Old 6th October 2012, 07:04 PM   #331
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by JRKO View Post
Cant this be achieved with born and bass/mid driver like the 18FH510?
if you mean in a 2way ?
lots of power for rock, but no way a violin will ever sound like a violin, like you requested
but I really think you need just a little more low end
early rolloff is not equal to tight controlled bass
I would say 'on the contrary'
Old 6th October 2012, 07:21 PM   #332
JRKO's Avatar
Send a message via AIM to JRKO
Leaving power to rock aside can a 2-way not reproduce accurately? I know the one pictured below is way over what I can build but surely that cant reproduce violin etc?
I didn't get what you meant by "I really think you need just a little more low end"
thanks for sticking with me on this.
I'm still interested in your idea to buy a horn & CD and go from there
If I'm not making noise, I'm making something to make noise
Old 6th October 2012, 07:29 PM   #333
not impossible
Old 6th October 2012, 07:33 PM   #334
JRKO's Avatar
So is it the midrange, 100hz - 1000hz that is the key to perfect reproduction? With a hefty bass foundation and sensible cd&horn above
Old 6th October 2012, 07:35 PM   #335
I meant to say not to be happy with 50hz, but aim a bit 'lower', like say 30-35hz
rolloff means phase shift
no, not that simple
simplificated, the 'key' is crossover phase
or more accurately, the result of what it does
Old 6th October 2012, 07:39 PM   #336
buzzforb's Avatar
It appears to me the that the 15hf510 can easily handle 50-740/1000 and can blend well with either midrange or horn. You may not get super low, but that leaves option for sub if needed. Considering your room, it may be unecessary and room gain will be more than adequate. Althought other parameters are different, it has a similar response as the Altec 416, lacking the bottom end of course.
...Shape the sound , Man!
Old 6th October 2012, 07:48 PM   #337
very important to find a combination with smooth fit
or try Fane 15-400LF in closed, it only needs to be very big
but thats the topic, so....
Old 6th October 2012, 08:05 PM   #338
1.6khz on up - Radian 475PB + SEOS-12
300hz - 2khz - 2X BG Neo 10 / horizontally mounted and stacked vertically
100hz - 600hz -2X B&C 12TBX100 / Cardioid
15hz - 120hz - 4X Mach V LLE-18
...That's what I wanna do as my next project. Well maybe a SEOS-RAAL with 140-15D and a AE TD12X.
Who wants to fund it???
Old 6th October 2012, 08:52 PM   #339
ingvar ahlberg's Avatar
Maybee, but i would go for 15 or 12", x-over quite a bit higher and stay 2-way.
The QW-1 has been built all over the globe and i´ve never heard any one not satisfied, although many builders have chose to x-over a lot lower than i would.
There´s many good 15" drivers around that will do just what i think You want, even more 12" which i think is the best size for a voicereproducing driver, the choice of HF driver/horn is gigantic but there´sa few new contestants that, imo, beat all competition and also are decently priced.
Ingvar
Old 6th October 2012, 08:57 PM   #340
buzzforb's Avatar
Care to name a few from your experience?
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 02:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 03:53 AM
Copyright ©1999-2017 diyAudio
