And Now For Something REALLY BIG - Page 33 - diyAudio
Old 6th October 2012, 10:14 AM   #321
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
and the side walls ?
anyway, if your room really is small, forget about big speakers
big woofer, ok, yes, will do
but for a midrange you would need something much smaller
good 5" on a big shallow waveguide would be very nice
Old 6th October 2012, 12:53 PM   #322
Alternatively you could buy some Tannoy DCs off ebay.
They'll work in any room big enough to fit them in which, I suppose, would be equally true for other co-axials.
Currently there are a few 12" 3142 drivers on offer and one guy is selling 4 Pumas (15" DCs!) for 800, no bids and one day to go!
You could sell one pair and use the proceeds to build something like these:
tannoy or even use 18" instead of the extra 15" woofer.
Old 6th October 2012, 01:36 PM   #323
I think the main problem still exist, with any big drivers, coax or not
the 'forward sound tendency' needs more space to get did of the aggressive 'in your face' sound
Old 6th October 2012, 01:56 PM   #324
I got the gist that JRKO is after an 'in your face sound' but the apparent sound source with Tannoys is about 30cm behind the voice coil so you'd gain a bit of virtual space.
Either way I never had that problem with my own Tannoys, they make excellent near-field speakers and that is my preferred way of listening.
Old 6th October 2012, 03:47 PM   #325
Originally Posted by JRKO View Post
All seems fine and then when you turn it up just a bit too much it grabs you by the throat, shakes you around and spits you out.
ah, ok, you say it was meant to be positive glad Im gone then
Old 6th October 2012, 03:59 PM   #326
Elias is offline Elias  Finland
Elias's Avatar
That is the general symptom of too high directivity at high frequencies.
There ought to be enough of early room reflections to cure this nasty illness.
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 6th October 2012, 04:50 PM   #327
JRKO's Avatar
Send a message via AIM to JRKO
I've been down the Tannoy DC route. 10" Eaton & 15" Berkeley. Fun while it lasted
Not really in your face. Describing sound is tricky. I want to be able to play at realistic levels should I wish, but will be lower much of the time. I want a double bass to sound like a double bass, a violin like a violin and Alison Krauss to sound like........well you get it. Pared down music to sound open an haunting and live recordings to sound live. I know a great deal of this is down to the recording but if its there, I want to hear all this at ANY volume level. I guess glossy hifi mags would call it 'resolving'?
If I'm not making noise, I'm making something to make noise
Old 6th October 2012, 05:35 PM   #328
ah, then I was right
but how to do the crossover
Old 6th October 2012, 06:25 PM   #329
I want super fast ,clean & accurate bass with no overhang.
I'm a fan of large headroom
you will need lots of power, and bound to be a multiamp setup
efficiency ? 95db woofer with 92-93db mid will be very good
Old 6th October 2012, 06:45 PM   #330
JRKO's Avatar
Back to a 3-way again?
Cant this be achieved with born and bass/mid driver like the 18FH510?
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 02:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 03:53 AM
Copyright 1999-2017 diyAudio
