Old 28th September 2012, 06:00 PM   #181
JRKO's Avatar
Send a message via AIM to JRKO
my room isn't nervous - it might be when it sees these speakers tho
The Fountek ribbons look cool but have lowish power handling for a sensitivity of 93dB/w/m. They'll not stand much power compared to the mid & bass if I give it some. The probably wont mate to the mids very well either?
Am I limited to CD with a horn?
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home
Old 28th September 2012, 06:18 PM   #182
IG81 is offline IG81  Canada
IG81's Avatar
It might be hard to find a dome tweeter that keeps up with the midrange level, though there are some. 2kHz at high power levels might be hard on the dome. It will also have a very wide dispersion pattern, contrasting with the narrowing behavior of the mid though.
IG
Old 28th September 2012, 06:26 PM   #183
Default ;-)
Originally Posted by tinitus View Post
with good well behaved speakers you wont need special room treatment
unless you have a really 'nervous' room
but might be true that many speakers using pro drivers could tend to be a bit 'nervous', and thus may need room treatment to sound good
unless you settle at calling it honest, analytic, clean, pure, true, or whatever suits
Loudspeakers are the 'muscle' of an audio system, nirvana come from somewhere else. I guess some need a semi-tractor-trailer to bring home the groceries. That would make any spouse nervous, particularly when it gets parked in the front living room.
WHG
Old 28th September 2012, 06:46 PM   #184
tinitus is offline tinitus  Europe
my friend got hold of a old pair of well built Cervin
I would say old enough to be vintage
15" woofer, 6" mid, small tweeter
anyway, they were ok, and played really loud and clean
just what he had dreamt of half his life
then I took out the mids and reversed phase
and we were both stunned, and couldnt believe what we heard
reluctantly I have to admit, its able to play louder than I can bare for very long, or at all for that matter, and it remains controlled, well behaved, and still sounds like pretty good hifi quality
and that with plain ordinary electronics
makes people laugh, I know
but believe it or not, it is real, and very surpricing, yes
I could hardly believe it either
mind you, I only know this one
and once again, it was only revealed only after reversing phase on the mids
food for thoughts I would say
Old 28th September 2012, 07:09 PM   #185
badman is offline badman  United States
badman's Avatar
Originally Posted by Robh3606 View Post
You can do that with subs. Also things start to sound a bit thin without that last octave and a half. Just pick the right midwoofers and subs and it can sound really good with the solid foundation subs give you and all the snap you are looking for.
Rob
Absolutely. Also overlooked is the role of the deep stuff in ambience. You really do miss it when it's not there- there's a spaciousness to sound with true deep bass that simply doesn't happen without the bottom octave.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 28th September 2012, 07:11 PM   #186
I think a compression driver might be your best bet.
BMS make a few 1" ones which may be suitable. The 4544 and 4550 go down low enough for a 90x40 horn or you could use a 70 or 60x40 horn, cross at 1.9k and use the 4538.
The cheapest place for the latter is Thomann where it retails at about £60 a pop.
Old 28th September 2012, 07:21 PM   #187
JRKO's Avatar
I'd like to hear how you get nirvana without speakers! "Nice looking amp. How does it sound?" ---- It doesn't. "Cool turntable!! how does it........?"
And yes, 'some' do need, and worst of all want, larger speakers. 'Some' may be content with a wicker basket on the front of a bicycle 'to bring home the groceries' - and good for them!
To be clear I'm only after design help. I don't require and am not soliciting validation, permission, approval or disparaging comments. There is yet not sufficient information to say these speakers will be too large, will cause sonic issues within their final resting place or create any noticeable change in spousal wellbeing.
They are going to be big. Otherwise the thread would be titled 'And now for something REALLY............normal'
Old 28th September 2012, 07:23 PM   #188
JRKO's Avatar
anyway, they were ok, and played really loud and clean. just what he had dreamt of half his life
Yup! sometimes things just work and it can be the simplest of changes that make the difference
Old 28th September 2012, 07:25 PM   #189
JRKO's Avatar
And again, Yup! I find its like adding a tweeter to my 12lta - more space more air etc etc. Add a sub and again the space opens up farther, if not more!
Old 28th September 2012, 07:28 PM   #190
Vix is offline Vix  Yugoslavia
Vix's Avatar
Why not use the Econowave recipe. Crossed at around 1khz. Midbass wouldn't have to go too low. Then, add a pair of 18" woofers for the bottom octave, and you're happy
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 02:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 03:53 AM
Copyright ©1999-2013 diyAudio
