And Now For Something REALLY BIG
Old 6th February 2013, 10:59 AM   #831
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by JRKO View Post
cheaper than the 510 ...ported 75l cabinet tuned to 45hz ....
the neo 500 ought to give you a small bit more bass output than the ferrite 510, due to the slightly higher Qts, all else being the same, but maybe only theoretical
There's always this type of tractrix to try. It looks a tad simpler....
looks more like a modified Iwata to me
add rounded solid wood at front edge of top and bottom, and you have it
the construction still does have a few weird angles that tend to be difficult
but it looks cool
Old 6th February 2013, 11:10 AM   #832
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Thats what WinISD shows too. More depth, slightly less snap I'd guess.
510 has a -3db of 63hz when tuned to 52Hz
I will have some control with the miniDSP as well thou
15PR400 behaves similar to the 500 but the QMS is 6 as opposed to 10 (qes & qts are comparable)
Several of those non circular tractrix type horns show up in a google search for tractrix. Only the two vertical sides follow the tractrix curve
If I'm not making noise, I'm making something to make noise
Old 6th February 2013, 12:48 PM   #833
I have thought about 'lining' inside of top and bottom with acoustic foam
Old 6th February 2013, 01:00 PM   #834
JRKO's Avatar
I have to think how to paint the multicells so Mrs JRKO is more approving Gonna be kind of white inside and natural cork outside
this is the only practical idea I can find - How to paint Multicell horns?
Old 6th February 2013, 01:20 PM   #835
hmm, some surfaces will always look slightly scruffy, no matter what you do
maybe best the answer is the kind of 'structural paint' used for PA speakers
but probably best use it only on outher surface, and maybe mouth area
but if she is to the 'antique' look, there might some other options like maybe a stained copper look
leaf gold ? maybe you can get 'leaf copper' too
Old 6th February 2013, 01:26 PM   #836
JRKO's Avatar
As the 'cells are mdf they should take ok. I kind of like the fill a cell with paint then open the bottom idea. I wonder about spraying them with a primer first?
So long as they look better than plain ole mdf its ok
natural cork is supposed to help with resonance of these non metal 'cell sets
Old 6th February 2013, 01:30 PM   #837
mdf is usually one of the better surfaces for paints
Old 6th February 2013, 01:39 PM   #838
JRKO's Avatar
wife saw this and said 'No'
Old 6th February 2013, 01:40 PM   #839
JRKO's Avatar
wife saw this and said 'Okay'
Old 6th February 2013, 02:18 PM   #840
ofcourse
try with a touch of very light yellow
And Now For Something REALLY BIGHide this!Advertise here!
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 03:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 08:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 07:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 04:53 AM
Copyright ©1999-2017 diyAudio
