And Now For Something REALLY BIG
Old 30th January 2013, 10:32 PM   #821
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Hi James,
I was away and didn't catch up on your ear damage until now. So sorry for you. I hope the others are right and that patience will pull you through until it repairs itself. I can't believe you are even thinking about audio right now, unless of course it is a type of relief from the other things.
Also sad that things didn't work out right away on the horn front. It did seem awfully ambitious so I hope you aren't letting it bother you too much. I don't think I would have been brave enough to try that. I am having a hard enough time with foam board and a hot glue gun making Cornu copies.
planet10 needs your help:
Let's help Ruth and Dave
Old 30th January 2013, 10:53 PM   #822
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Thanks Cal. I cant quite muster the £50 I need to get a laser gut guide for the final paper horn - especially if I cant make the general basic working model
There's always this type of tractrix to try. It looks a tad simpler....
.....famous last words
If I'm not making noise, I'm making something to make noise
Old 30th January 2013, 10:55 PM   #823
JRKO's Avatar
BTW have you seen this little setup?
multicell heaven click on the images to enlarge
I love the multicells as stand alone speakers in their own little cabinets.
Old 30th January 2013, 11:01 PM   #824
Speakerholic
Cal Weldon's Avatar
Dream indeed. I think that's a great way of serving up a multicell. I also can't help but notice the similarity of the bass horn with a Cornu. I wonder if he has incorporated some Fibonacci in there.
I'm going to put that link in the Cornu thread, thanks.
Old 2nd February 2013, 08:32 AM   #825
JRKO's Avatar
here are a couple of pic ideas for the bass cabs. Its called Shou sugi ban. Heres 2x little video linky:
Shou Sugi Ban being in Japan
http://www.youtube.com/watch?v=L4CeJIaI5Vg
You can brush and wash it to smooth it out as well if you prefer a smoother look
What do you think as a facia cladding for the bass cab?
Old 5th February 2013, 11:30 AM   #826
JRKO's Avatar
10 cell (5x2) multicells are on their way
starts looking at minidsp..............
Old 5th February 2013, 11:53 AM   #827
AStroop is offline AStroop  Germany
Hi JRKO,
I tried starting a new thread, but for some reason I have had no takers, so I thought I would just ask you!
I am wanting to do something very similar and was wondering what configuration for the Bass cabinets are you looking at now? Last I saw was that you were going to use faitalpro. But as a bass reflex or onken or something else? Maybe I missed something. If so sorry!
Cheers
A
Old 6th February 2013, 04:58 AM   #828
Rob41 is offline Rob41  United States
Rob41's Avatar
Originally Posted by ingvar ahlberg View Post
I also like large drivers and still believe that You cant beat qubic inches.
But, i don“t like x-overs, especially if they“re used in the fundamental voice region, say 300-3kHz.
This means i have to use LF drivers that are very good in the voice area, 10-12" is, in my opinion, the best choice for this.
We still want the fantastic low level dynamics that large drivers deliver, what to do?
First try, turned out really ok, was this:
A tiny litle speaker that actually is allmost a 2-way design, the larger of the round parts is a Beyma 21L50, this ,unfortunately out of production, 21" driver is lowpassed at about 85Hz, the smaller round thing is a Beyma 10G40, only lowpassed at about 3k, firing backwards in what could be regarded as a TQWT but with exponential expansion.
The square thing is a Beyma TPL150, AMT driver, system sensitivity at around 100dB and fantastic low-level dynamics.
It moved furniture at pretty modest levels so the 21" was perhaps a bit too large for our livingroom.
What to do then?
Ingvar
Your speakers are beautiful Ingvar! It's ironic that I saw them because I've been conceptualizing something very similar in appearance. I plan to build a similar set but quite a bit more modest with a tiny 15" woofer, 8" mid and a planar tweeter. Although mine will be a bit smaller, I'll separate the speakers into top and bottom cabinets.
Thanks for posting the pics; it's great to see what I'm shooting for.
MiniDSP 4x10/Nikko Alpha 650/SAE 2600/SAE 2400/Soundcraftsmen MA5002/Heathkit AA-1800/Heathkit AA-1600
Old 6th February 2013, 10:29 AM   #829
JRKO's Avatar
I'm aiming to go FaitalPRO | LF Loudspeakers | 15FH500 (because they are £50 cheaper than the 510 each at the moment and still look very good) in a ported 75l cabinet tuned to 45hz that gives me a -3db at 50hz and -9db at 38hz. All info taken from WinISD.
Old 6th February 2013, 10:32 AM   #830
Excellent! Thanks for that!
Cheers!
And Now For Something REALLY BIGHide this!Advertise here!
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 03:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 08:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 07:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 04:53 AM
Copyright ©1999-2017 diyAudio
