And Now For Something REALLY BIG
Old 19th January 2013, 02:26 AM   #801
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
ok Im still pot bound!!
As I understand:
terminal 1 = input
terminal 2 = output
terminal 3 = gnd
at the moment I have input & output wired but gnd goes strainght from the phono to the gnd on the board = full volume no control.
Would the gnd wired from phono to terminal 3 then to gnd on the board sort this?
here is the spec of my pot
im confused.......please halp (because even with only one ear working this is annoying ) There are so many different wiring 'options' espoused on the net...........
according to http://sound.westhost.com/pots.htm 3 is input, 2 is output and 1 is gnd AAARRRRGGGGHHHHHHH
If I'm not making noise, I'm making something to make noise
Old 19th January 2013, 02:35 AM   #802
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Just use you mm to find different points of pot. If connected to 1 and 3, you should get total resistance of pot. If connected to 2 and 3, you should be able to vary resistance. Consider what a volume pot does and simply use mm to figure out what goes where.
...Shape the sound , Man!
Old 19th January 2013, 02:58 AM   #803
JRKO's Avatar
tnx buzz
I have 10k across 1 & 3 and I have 0~10k across 1 & 2 as well as 2 & 3 meaning.....
aww I dont know what it means. Its 3am, I'm half deaf, cant wire a damn pot and my cat just crapped under my desk.......damn cat
'Kicks cat out of bedroom, goes back sleep until at least 4am'
Old 19th January 2013, 03:07 AM   #804
JRKO's Avatar
okay, throwing cat out woke wife so I got banished too!!
All I can discern fro the above is that terminal 2 is output. I think........
O crap I dont know. How can build a NP KT and fail at sorting a pot of all things?
'sneaks back to bed as wife snoring' - no dear you don't snore (much) must be the cat.......
Old 19th January 2013, 06:41 AM   #805
JRKO's Avatar
just my stoopid gnd wiring holding it back.
Do or die test at 6am. It was wither gonna work or play full volume...........IT LIVES
now my miniDSP is somewhere in the snow near Heathrow so maybe, soon......
Old 19th January 2013, 10:15 AM   #806
buzzforb's Avatar
Good to hear. Dumb cat!
Old 21st January 2013, 04:54 AM   #807
JRKO's Avatar
OK descisoin time
one of louis lovely hand turned tractrix horns http://www.diyaudio.com/forums/vendo...ml#post3317748 made for a 600hz cutoff
or the 8 cell 8 Cell Multicell Horns for JBL,Beyma,Altec, | eBay
Still loving the 8 but the tractrix is cool. Pulling the trigger today so jump in guys!!!!!
Old 21st January 2013, 05:13 AM   #808
GM is offline GM  United States
GM's Avatar
Depends on how wide a 'sweet spot' you need. Tractrix beams with increasing frequency much more than a multi-cell.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st January 2013, 05:20 AM   #809
djn is offline djn  United States
djn's Avatar
I run 350hz round horns and they do beam like crazy bit I only sit on the sweet spot so that is ok
Old 21st January 2013, 06:55 AM   #810
JRKO's Avatar
I'll be running 600/650 absolute lowest down a room 11' wide and prefer a wide sound spread as possible as possible. Sound stage is usually an illusion these days, mastered into a recording rather than carefully coaxed from the actual performance of years gone buy
chalk up 2 for multicells!!
Pano is a 'cell type guy (no I dont mean top bunk, keeps a pet cricket and steals your meds)
So thats 3 to the multicells!!!
And me makes
well 4 and I'm the dealer so house wins!!!
And Now For Something REALLY BIGHide this!Advertise here!
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 03:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 08:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 07:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 04:53 AM
