And Now For Something REALLY BIG
Old 26th September 2012, 04:30 PM   #61
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Pano View Post
never boomy.
maybe thats what he expects
Old 26th September 2012, 04:34 PM   #62
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Originally Posted by tinitus View Post
ehh...no, too heavy
then you need one of the lighter coned semi pros
though my advice was to stay away from those, they might be the ones for small amps
usually smaller amps are more 'polite', and not for playing that loud either, so it might still work ok
Thanks tinitus. Would 8w work at home levels? its 98dB/W/m, 0.28 Qts & BL of 26.6 which is huge !!!!!!
What would you say the advantage to an 18 over a 15 other than pure size?
If I'm not making noise, I'm making something to make noise
Old 26th September 2012, 04:45 PM   #63
JRKO's Avatar
I'll dig up the Onken specs when I get home, if you don't find them first. Search for 360 L Onken. I like the big Onken with the Altec 416 very much.
is this them?Untitled Document
Are other drivers suitable?
Some 'vintage' speaker designs I've heard were, um, sloppy. Don't know if this is poor execution but it was sort of vague and wandering. Like talking to a batty old Aunt - harmless enough but not very exciting
Old 26th September 2012, 04:46 PM   #64
lower Fs
Pano suggested Onken
might work better for flea amp power
what is ? tubeamp ?
Old 26th September 2012, 04:51 PM   #65
happens when you put a high Qts dipole woofer in a box
Old 26th September 2012, 04:52 PM   #66
JRKO's Avatar
Lots of amps are available, both now and to make!
Maybe I'll leave the 8w for the hi freq
Fs is 37 on the PD188 as opposed to Fs of 39 on the PD154 & PD158
Old 26th September 2012, 04:56 PM   #67
PD154 and PD158 both have exstremely Qts
bass will be very tight, and probably even roll off early
in worst case you might say, why is there no bass
Old 26th September 2012, 05:05 PM   #68
Pano is offline Pano  United States
Pano's Avatar
Oui, c'est cela, meme. (Yes, that's the very one)
Not too much, no. But the enclosure can be adapted to other drivers. The "Petit" uses the Altec 414, IIRC.
Not this one, not at all. Rather the opposite. Most of us are not used to a speaker with out overhang, resonances, slop, doubling. It can sound too clean for some tastes. Not the "clean bass" that comes from no fundamental/all harmonics, but clean from not having slop.
You'll find lots of photos on the interweb, take a look to see if you like its style or not. I think it's an impressive looking, as well as sounding cabinet.
Oh, I just remembered! Kevin, one of the mods, has a set of Onkens he dearly loves. I don't recall what driver he uses. We should ask.
Take the Speaker Voltage Test!
Old 26th September 2012, 05:07 PM   #69
JRKO's Avatar
OK so Qts of 0.2 shows quick fire punch but very lightweight bass but and Fs 0.45 has weight but maybe sloppy?
Other than Fs is there any other reason to pick an 18 over a 15?
Old 26th September 2012, 05:09 PM   #70
btw, Fane Studio 5HPM could be a sweet mid driver for a 'home' studio monitor
And Now For Something REALLY BIGHide this!Advertise here!
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 03:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 08:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 07:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 04:53 AM
Copyright ©1999-2017 diyAudio
