And Now For Something REALLY BIG
Old 23rd November 2012, 04:08 PM   #651
Pano is offline Pano  United States
Pano's Avatar
The joins between the cells do you mean? See photo below:
(Wow, had to take a flash photo to see how dusty it is in there!)
Old 23rd November 2012, 04:27 PM   #652
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Yeah I meant anont the front edge.
Ah ok. The other photo must have been taken around noon with the sun shining down on them (the shadow on the ground confirms) It cast a shadow from what is a very fine difference in height according to the 2nd photo.
An genuine trick of the light!
If I'm not making noise, I'm making something to make noise
Old 23rd November 2012, 04:34 PM   #653
Pano's Avatar
If you look closely at the photo in post #650, you can see that the cells were joined by a metal strip that follows the edge. That's how they are held together across the width. I suppose you could use tape.
There is one top and bottom and another in the center. The center one may be easier to see.
Old 23rd November 2012, 05:20 PM   #654
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I can confirm the measurements of the 1803 against the literature. The mouth openings are the same but I didn't realize the horn sections were longer than the 1505. I thought it was just 1 more row. Learned something today.
Also, Michael your width measure doesn't take into account the extra width at the center of the horn which according to the Altec lit., is an inch more either side. Mine measures 42" at the tabs and 44" at the center
planet10 needs your help:
Let's help Ruth and Dave
Old 23rd November 2012, 05:37 PM   #655
Pano's Avatar
What center?
Old 23rd November 2012, 05:44 PM   #656
GM is offline GM  United States
GM's Avatar
The horn's axial length must be longer to have a lower cut-off, hence the flare frequency will be lower for a given mouth area.
Note these are all expo horns, so with the throat, mouth area + axial length, the flare frequency can be calculated, then input these values into an expo calculator to get the expansion over distance areas to make a template.
IIRC, the larger multi-cells don't have all cells the same shape, so if they are all made identical, then their polar response will be different, maybe to the point of having too wide/tall a 'sweet spot' unless a relatively close LP is used.
I wonder if the wood horns are correct in this respect.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 23rd November 2012, 06:44 PM   #657
Speakerholic
Cal Weldon's Avatar
Originally Posted by Pano View Post
What center?
If you look at the mouth of the horn, the middle is wider than the tabs that you have measured.
I will go check.
Old 23rd November 2012, 06:49 PM   #658
Speakerholic
Cal Weldon's Avatar
All horns are identical.
All mouths are square.
Old 23rd November 2012, 06:52 PM   #659
Pano's Avatar
Got it. The center line is slightly wider than the top or bottom lines, yes.
Old 23rd November 2012, 06:58 PM   #660
GM's Avatar
Correct, but what about the horn expansion itself? IOW, are they all ~perfectly symmetrical sighting down the center-line or do they bend with at least one side being straighter?
Another thing I just thought of is that back when Steve and I were discussing these, we were talking about the old tar filled horns. I've no experience with the Aquaplas coated units, so wonder if Altec over time did a bit more cost cutting and began using just one cell shape.
GM
And Now For Something REALLY BIGHide this!Advertise here!
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 02:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 03:53 AM
