And Now For Something REALLY BIG
Old 21st November 2012, 03:18 PM   #601
LFM is offline LFM  Canada
Default something really big
I am going to use wood veneer built up in layers to create a plywood like structure. The material in the mouth and throat will be the more expensive veneer and subsequent layers cheaper. I will purchase sheets of veneer from Tape Ease. To shape, I'll just make a thick template and cut the stacked veneer blanks with a flush cut router bit. By stepping the veneer at the throat and mouth the thickness can be kept very thin. I am sure that if fiberglass resin is used as the glue between layers it will be strong. I'm still trying to find out more about the 1505 profile before starting.
Old 21st November 2012, 03:19 PM   #602
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
I was thinking carbon fibre as a stiffener perhaps? Actually I was thinking of a complete multicell made of it.........mmmmmmmm shiny
Perhaps not
I guess Hahnemuhle rag or some such photo paper could work as the interior of the cell.
Paper questions:
Would newspaper be adequate as a build up medium?
Thick paper in few layers or thin paper in many layers?
If I'm not making noise, I'm making something to make noise
Old 21st November 2012, 03:21 PM   #603
Pano is offline Pano  United States
Pano's Avatar
IIRC, what I used as the paper base was Arches Cold Press Water Color paper, 300 lb. Thick and very stiff. Here it retails for about $2.50 a square foot. Not cheap. But I think you could go with a simple cardstock of similar weight for much less money. And cardstock comes in many colors, so the inside of the cells could be gray, black, white, blue or pink!
The Altec cells are exponential, I believe, so look into that profile.
Take the Speaker Voltage Test!
Old 21st November 2012, 03:24 PM   #604
JRKO's Avatar
'The WayBack Machine' did a crawl over the DIYAudio page containing Petter Persson's multicells 24th October 2009. The thread was started 20th Jan that year.
Here is the link http://web.archive.org/web/200910240...cell-horn.html
the server holding that info is down at the moment but should be up soon.
Old 21st November 2012, 03:26 PM   #605
Pano's Avatar
Be careful with the wet mash. I can really soak into and destroy your base layer. Build a few cells and experiment is the best advice I can give you.
Or do as LFM is doing with thin wood strips of veneer.
Old 21st November 2012, 03:27 PM   #606
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Originally Posted by Pano View Post
if they did not need to be super sturdy like pro horns that are made of metal.
Mine tend to bend at the mouth when I look at them the wrong way. Nice thing is you can easily bend them back.
planet10 needs your help:
Let's help Ruth and Dave
Old 21st November 2012, 03:34 PM   #607
Pano's Avatar
At the smaller size of the 1005 or 803, the metal seems sturdy enough. Might be a good indicator not to go too large with paper!
Old 21st November 2012, 03:42 PM   #608
JRKO's Avatar
how about adding balsa or carbon fibre (as light but stiffer in 1mm strip) strips along the cells walls?
Old 21st November 2012, 03:49 PM   #609
Pano's Avatar
Unless you go really big, like Cal's 1803, I doubt you'll have any trouble. Even the metal horns don't weigh much for their size. They are mostly air.
The tar filled versions, on the other hand, are beasts.
Old 21st November 2012, 04:35 PM   #610
buzzforb is offline buzzforb  United States
buzzforb's Avatar
excellente info!
...Shape the sound , Man!
And Now For Something REALLY BIGHide this!Advertise here!
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 03:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 08:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 07:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 04:53 AM
Copyright ©1999-2017 diyAudio
