And Now For Something REALLY BIG
Old 16th November 2012, 10:25 AM   #571
freax is offline freax
freax's Avatar
Originally Posted by JRKO View Post
D'OH!!!!! Curse my Mac keyboard!!! I divided instead
yes its 3.26"
lol you should use an Amiga keyboard, thats what NASA used to use: Video: NASA Morpheus moon lander crashes & explodes on test flight - YouTube
I blame the transition to Windows computers.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 16th November 2012, 02:13 PM   #572
multitask is offline multitask  Denmark
Originally Posted by LafeEric View Post
I have also purchased a pair of D220Ti's but am working on finding the right horn, currently.
probably you have already chosen a horn. but these work good for my 220s.
https://www.parts-express.com/pe/sho...umber=292-2572
smooth compared to earlier cd-horns that have edges in them. and can be crossed pretty low.
Old 16th November 2012, 05:07 PM   #573
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Holy poop!! Your replying now to LafeEric who posted that 553 posts ago???
I'm just guessing but did you read the whole thread before posting randomly
If I'm not making noise, I'm making something to make noise
Old 16th November 2012, 05:17 PM   #574
JRKO's Avatar
So I have 2 other parts of the puzzle to collect before I can use the HF144's.
Unfortunately they dont come in cereal boxes thou finding a minidsp in you cherios would be less of a shock than a 8 cell horn
It will be the end of the month before I can raise the 200 for the horns and then a week or two for the minidsp, unless I can lose that in the monthly shop somehow
I am going to need a preamp at some point too but I guess I can make do with the volume control on the minidsp for a while. I'm heading towards a battery powered B1 with board & jfets from Nelson himself.
I think I can power the minidsp from a battery as well. I wonder what the benefits would be? Other than the obvious - getting it of the crappy circuits in my block and one less mains socket needed!!
Old 16th November 2012, 05:20 PM   #575
GM is offline GM  United States
GM's Avatar
Originally Posted by einis View Post
Hmm, its mouth transition is much too abrupt. Adding a foam lip ALA Peavy's Quadratic Throat WG patent is a good plan. That, or a foam insert after Dr. Geddes's patent.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 16th November 2012, 05:35 PM   #576
GM's Avatar
a 8 cell horn
Which one?
If your mains power is as bad as mine, battery power is de-riguer for HIFI/HT apps if you don't have a power conditioner. Worse is all the shielding required in my locale. 'Customer no service' AT&T's crappy DSL modem can't hardly function without shielding and even then, their line filtering leaves something to be desired if I understand correctly how this system works.
GM
Old 16th November 2012, 06:24 PM   #577
JRKO's Avatar
This one 8 Cell Multicell Horns for JBL,Beyma,Altec, | eBay
Would value your input on this one GM
As for power, I am thinking of using the ACA (5w class A) for the HF144's and for midbass a Hifimediy T1 (100W into 8ohms ) both of which I can power with SLA's!!
I thought Ideally I could get my entire system from preamp upwards of grid and just have the sources on the mains.
Old 16th November 2012, 08:55 PM   #578
GM's Avatar
Hmm, larger than an 808, smaller than an 805, so guess it's designed for the 20-20 kHz BW's mean equal power point = ~632 Hz XO.
The throats don't come to as sharp a point as the tin 'can' horns, so HF response won't be quite as smooth/extended, but overall looks like a good bang/buck product.
Sure wish I had the patience! I wonder how much a [12] cell would be to get down to 500 Hz [1205].
GM
Old 16th November 2012, 09:12 PM   #579
JRKO's Avatar
is the 632hx the cut off for this multicell so I should crossover higher, say 750hz?
the guy also makes a 15 Cell version. We noted some odd details in the throats pics. From the builder - 'Because of the widening of the of the entrance it keeps all the 15 appertures the same area never thought about it before" & "yes the cells are slightly shorter on the outside banks but the throats make up the differance by being longer on the outside edges"
Old 16th November 2012, 09:53 PM   #580
JRKO's Avatar
GM
Just to clarify, do you mean small end or the large end of the cells are not as sharp? The guy seems open to small detail changes
And Now For Something REALLY BIGHide this!Advertise here!
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 02:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 03:53 AM
Copyright ©1999-2017 diyAudio
