And Now For Something REALLY BIG
Old 4th October 2012, 08:41 PM   #301
d to the g is offline d to the g  United States
d to the g's Avatar
[IMG][/IMG]
Plus, the 414 really bumps.
Old 4th October 2012, 10:43 PM   #302
djn is offline djn  United States
djn's Avatar
Can you tell us a bit about that speaker D? I like the horn.
Old 5th October 2012, 02:30 AM   #303
d to the g's Avatar
It's an bastardized Altec "the carmel" with a pair of 414z in an open back configuration. The horn is from Jeffery Jackson's "elevenhorns" with a TAD 2001. The horn and driver are on loan from a friend, the TADs are beyond my reach. My room is pretty small, like 12'x14', and these are about 1/3 of the way into the room. They definitely move a lot of air, even open.
Currently, I'm running them first order at 800Hz but it's not the best crossover by any means. I'm waiting for minidsp to finally get my plugin code, but it's like pulling teeth. When that happens I'll biamp and play around trying to figure out where and how I best like them crossed.
Old 5th October 2012, 08:53 AM   #304
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Originally Posted by Pano View Post
Sure, but shipping and import/VAT UK style would raise that amount a lot.
tell me about it!! 20% of the cost of the item AND the postage =
I'm gonna plug some numbers from a few of the proposed drivers into the onken calc to see if I can get lucky on the vents
If I'm not making noise, I'm making something to make noise
Old 5th October 2012, 02:02 PM   #305
JRKO's Avatar
ok - ive tried with a FP driver and an PD driver and I cant get any sensible. Tiny boxes being projected - 80l or so not including vents. I dont get it. I'm not even sure that I can enter the Sd values correctly.
Anyone out there with a non Altec Onken? Or does anyone have a couple of brain cells I can borrow? I have the feeling I'm being a bit thick
Would a simple sealed or vented arrangement be suitable instead, without loosing the magic?
Old 5th October 2012, 03:28 PM   #306
Charles Darwin is offline Charles Darwin  United Kingdom
I've mail ordered some t-shirts from the US once. They charged me 17% import duty and 20% VAT on top of that!
Never had much luck with Onken calculators.
Tried it with my Tannoys and my Volt woofers, the result was tiny cabs with vents over a meter long.
Never quite figured out what makes a driver suitable for Onkens.
The Volts are in transmission lines now and I couldn't be happier!
They are fairly big though but that should not be a problem for you.
Old 5th October 2012, 04:43 PM   #307
JRKO's Avatar
Glad I'm not the only one.
The altecs seem to have a low Fs (26hz ish) and MASSIVE Vas of 26cuft or 736l Makes them a rather tough act to follow.
options options options
Old 5th October 2012, 05:21 PM   #308
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
hmm....try look at Fane 15-500 in vented/BR
Old 5th October 2012, 07:33 PM   #309
your main problem may be that low Qts will never be low budget
try calculate Onken with PD.158 or PD.122
and you need to fiddle with port area and length to make it match your box front
I dont think ports should be less than 1" wide
and also adjust with the 'deviders' also working as side panel bracing
Old 5th October 2012, 09:52 PM   #310
Pano is online now Pano  United States
Pano's Avatar
The Onken is a bass reflex. You don't have to take the box size for BR that a calculator gives you, it's just trying to find the flattest response. EBS (Extended Bass Shelf) is another way to align the cab. If you can run Unibox (in Excel) have a look at that.
Yes, the old driver have huge Vas, and that's part of what makes them work in the big Onken/Ultraflex box.
But let's back up a little. What are your real goals? Are you looking for super clean bass that can be run off an SET amp, or do you just want big bass fun? Lots of driver surface area, like 1 or 2 18s per side will get you big bass fun and stay real clean at the power levels used in a home. Once you start to get a lot of surface area, the bass gets clean and big. You might need to EQ it some if the box is too small, but you'll have so much headroom that isn't a big deal.
Take the Speaker Voltage Test!
And Now For Something REALLY BIGHide this!Advertise here!
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 03:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 08:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 07:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 04:53 AM
