And Now For Something REALLY BIG
Old 29th September 2012, 09:15 PM   #211
Charles Darwin is offline Charles Darwin  United Kingdom
I think Faitals are fairly reasonably priced. You might find something here:
Bass & Mid Range | CPC | Results
Old 29th September 2012, 09:17 PM   #212
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Precision Devices
18" PD188 200
15" PD154 160
Faital Pro
18" 18FH500 242
15" 15FH500 212
If I'm not making noise, I'm making something to make noise
Old 29th September 2012, 09:19 PM   #213
Pano is offline Pano  United States
Pano's Avatar
Looks like a plan. PD 15 at the bottom, Faital CD at the top. Horn TBD. That could work well.
I had been looking at the PDN.15SB40 Neodymium 15", but the ferrite has a lower FS and might work well. The Neo looks a little better up top, but without seeing distortion, who knows?
Old 29th September 2012, 09:24 PM   #214
CPC sells the Faital 15FH500 for 161 incl. VAT when in stock, 210 for the 18. Or get better Faitals for the same cash and they appear to be in stock.
Old 29th September 2012, 09:36 PM   #215
Rojoh is offline Rojoh  Norway
Rojoh's Avatar
PD 15"s at work in Adam Audios big monitor. I guess one could do worse. Personally I really like my PDN15BR40s, but I'm not sure PD delivers neo-models any longer(?)
Putting out fire with gasoline.
Old 29th September 2012, 09:44 PM   #216
Pano's Avatar
Cool!
JRKO - I'm a bit lost. Are you still doing 15+horn, or a 8-10" cone mid and tweeter?
Old 29th September 2012, 09:44 PM   #217
Suppose the end result could look something like this:
M1 Speaker
Just without the $100 000 price tag. ;-)
In fact the horn looks a bit like a Beyma TD235 ground flush along the edges.
Old 29th September 2012, 10:10 PM   #218
Rojoh's Avatar
M1 Speaker
At least my suggestion would be a 3-way system where the woofer and mid crossed somewhere in the middle of eachs floorbounce-freq. (3-400Hz). For modest level listening I'd like to try something like Seas MCA15RCY + the DXT together with a good sounding 15" pro-woofer.
More money and more SPL: PHL mid/woofer and perhaps 18Sounds XT1086 horn with tbd CD.
Old 29th September 2012, 10:27 PM   #219
Nobody said that it has to look exactly like that.
It was merely an example since the driver set up would be rather similar yet JRKO intends to spend about 2% or so of the M1s retail price.
Old 29th September 2012, 10:41 PM   #220
Rojoh's Avatar
Budgets are ment to be blown, aren't they? Yes, first lesson in the tour de audio would be someting like: If budget is final - buy hedaphones.
Secondly: One of the owners of M1 is the russian president Medvedev. I guess he don't have time to DIY.
(Roomsize is probably OK too...)
And Now For Something REALLY BIGHide this!Advertise here!
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 03:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 08:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 07:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 04:53 AM
