And Now For Something REALLY BIG
Old 27th September 2012, 04:55 PM   #141
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
btw, there's nice new 8" from 18sound...8MB500
though Im not sure it sounds any better than Beta8
or may even be worse
all you may get for sure is better build quality, and probably a tougher driver
old 8MB400 is on sale at Lean and looks like a bargain, if its any good
measurements look different, but that could rely on many other things, and not mean anything, hard to say really
Old 27th September 2012, 05:08 PM   #142
Originally Posted by JRKO View Post
...... like it can handle 2khz just fine and would push more air
be careful with measurements
may not sound like it looks
bigger drivers are usually not very good above 1khz, but ofcourse depends
but you really have to know the driver well to rely on anything above that
and many drivers(most) will probably fail long before that
but again, playing loud, the smaller driver may fall first
Old 27th September 2012, 07:13 PM   #143
IG81 is offline IG81  Canada
IG81's Avatar
Oh great
The great and mystical Baffle Step Correction
How does that work on these very wide speakers? Wide is good right? (gets hit by wife )
The ideal situation is to have a speaker large enough, that baffle-step is around the point where room gain kicks in. Speaker placement versus the floor, side and back walls allows for some "fine-tuning" with regards to this.
I just finished building large speakers of my own, 22" wide and 37" tall. Baffle step should be around 200Hz, but I don't feel like I need any correction with them in my 10'x13' room. Alternatively, since you want a ~200Hz Xover, it might land pretty near the baffle-step point and all that will be needed is to adjust driver levels accordingly, if at allnecessary.
IG
Old 27th September 2012, 09:01 PM   #144
badman is offline badman  United States
badman's Avatar
Breakup and beaming are separate issues but are both results of the freq. wavelength being smaller than the cones diameter and thus ending pure pistonic motion
Incorrect- breakup is much more closely tied to stiffness- which decreases with increasing driver diameter assuming constant cone thickness.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 27th September 2012, 09:23 PM   #145
Keriwena is offline Keriwena  United States
In a strict mechanical engineering sense of the term, yes.
With speakers, "breakup" is used more loosely. Guitar players use it to refer to harmonic distortion (mostly caused by exceeding Xmax), what you're referring to they call "cone cry".
In hifi, it's most often used to refer to the notchy hash above the wavelength/diameter limit, much of which is the comb filtering that causes beaming.
Real cone breakup tends to generate a high resonant spike, and can most often be seen in tweeters and fullrange drivers.
Old 27th September 2012, 09:31 PM   #146
djn is offline djn  United States
djn's Avatar
Originally Posted by VT67 View Post
Now this is an interesting thread. A few years ago I built a pair of Iwata horns designed for a 2" driver. Up until now I haven't found a suitable bass cabinet to accomodate these horns. The main idea was/is to keep it a two-way system. Suggestions are welcome. As you can see in the picture they serve as a printer stand and collect dust
This is basically what you have the start of. Best speaker I've ever heard. Build a 6cu ft box and use either the TAD 1601 15" woofer or the Lambda TD15X woofer. Then use either a TAD 4001 CD on the horn or a JBL 24xx CD with the True Extent barrilium (sp) diaphragm.
For me, best 2 way you can find.
http://www.youtube.com/watch?v=S11nqJmqYKs
Old 27th September 2012, 09:39 PM   #147
djn's Avatar
He is the evolution on my old room. Then a pix of the new reduced system in my new room.
Old 27th September 2012, 09:45 PM   #148
badman's Avatar
The notchy hash doesn't take place with metal cones, until the failure of the material stiffness. The off-axis falls off cleanly. The off-axis misbehavior in softer coned speakers is due to damped breakup.
Speaker Building Supplies from Madisound
In Hifi we're talking about breakup, not only high-Q breakups, but any breakup in the mechanical sense. Guitar speaker talk definitely is more loosely defined, but their light floppy cones tend to "break up" mechanically much more easily than hifi cone assemblies.
Old 27th September 2012, 09:49 PM   #149
Ooooooooo! I like the new chairs!
What? What do you expect me to say?
Old 27th September 2012, 10:00 PM   #150
Huh? That thing hits 2K then BAM! Don't let the smoothing fool you.
But that's what I'm saying, really - the "breakup" is caused by acoustic realities, not mechanical limits. Most folks aren't driving their hifi speakers to where 'cone cry' is an issue.
Then again, given the subject of this thread, it might be a consideration.
And Now For Something REALLY BIGHide this!Advertise here!
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 02:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 03:53 AM
Copyright ©1999-2017 diyAudio
