LFE + sub crossover - diyAudio
Old 23rd September 2012, 11:44 AM   #1
Angry LFE + sub crossover
I am using yamaha av amplifier with my homemade HT loudspeaker set up..Everything is running fine exepct I have a doubt regarding crossing over the Subwoofer. I have used a plateamp for the SW..but there is no direct LFE input on it..the LFE signal is controlled by the crossover..that there is no direct path of the LFE signal to produce the actual signal..since all my front speakers are large and are configured as large on the av amp..i adjust the crossover knob to the lowest on the plate amp... So what i am losing here..are lfe freq and sub amp freq summed up to present a different frequency altogether?..pls educate me on this
LFE Sofa judderod Subwoofers 2 19th December 2011 04:55 PM
LFE vs Line In Dubious Subwoofers 0 10th December 2006 05:01 PM
Decoding LFE cujo75 Subwoofers 12 28th November 2006 07:06 PM
SHould I use LFE or low level input PeterK Subwoofers 6 24th May 2005 03:32 PM
STK amps 4 5.1 Excluding LFE nz_ic_amper Chip Amps 0 16th October 2004 08:38 AM
Copyright 1999-2017 diyAudio
