#31 |
just another
Pano is right!! That's unfortunate it is 4 ohms. An actual impedance sweep would be good as it might show that it is higher in the range that matters.
Simulating at 4 ohms impedance, even with 400uF shows 0.65db down at 250Hz. 800uF takes that to 0.17db... so I think for the mid you are getting into teritory where a protection cap is going to have to be part of the slope. If you go digital you should be have the flexibility to deal with it if you are doing measurements. The cost of caps big enough to not have an effect in the pass band on the mid is probably going to be too high. Unless you go with electrolytics. You could use two of these 400uF 100V Non-Polarized Capacitor 027-376 in parallel on each mid for 800uF. PE have 200uF polyprops, but they are $64 each I won't get into whether or not electros will be audible or not... You could also look into DC protection circuitry. Basically a circuit that detects DC on the output and disconnectes (via a relay) the speaker output of the amp. Often these are used for turn on and turn off muting as well to stop pops and thuds. One of your existing amps may already have this as well. BTW once you know a few basics, simulating a circuit like this with LTspice is really easy (and it is free). Attached is the ASC file I used if you want to have a play with it to change the value of the components just right click on them and change in the dialog box that comes up. Click the little running man to run the sim, and click on the out1 and out2 to get the waveforms to come up. Tony. |
#32 |
I bought an active electronic crossover. It has XLR outputs and inputs, but I'll look for some adapters so I can connect it with the amps (rca)
I guess the Marantz has a built-in protection circuit (you can hear the relay clicking a second after turning on the amp), so there is no extra DC protection needed I guess. Now, for the mids and highs I could use the DIY 6 channel amp (without DC protection). What about building a DC-protection in the DIY amp? I found this kit from velleman, a company that provides DIY electronic kits: Velleman nv - Item - Details It costs about 20$ for a 2 channel protection kit. I'll need two of them. There is a second solution: I have a nice sounding Kenwood KA5700 stereo amp (with DC protection) that needs some clean-up, but could do the job for the mids and the highs, together. But with this stereo amp the mids and highs have to be crossed with a passive filter. What should I do? Going 3-way active and rebuilding my DIY amp with speaker protection while I'm looking for 2 good stereo amps that will do the job later? Or going 2-way active = staying with the marantz (lows) and the Kenwood (mids+highs) and using the passive filter that I use now for crossing the mids and the highs? |
#33 |
Again: a well done passive crossover is often better than an 'adapted' (as in not specifically designed/tailored for the drivers) Active.
And there's' none of the exact same gain requirement minefield. Some have even Bi amped through their passives with good result too.. same gain issues though. Best (necessary?) to have identical amps though No need to mention?? that the tonal differences in a multi amp setup can cause genuine havoc /chaos in the final sound balances :-) Lots of experimentation required, along all directions. Last edited by Bare; 27th September 2012 at 04:30 PM. |
#34 |
Thank you for your input, Bare. But passive filters are not the way that I will go now. Simply because I don't know at all how to make them.
I rather like to make an acceptable stereo setup with good drivers that aren't disturbed by a cheap passive off-the-shelf filter. I could buy a lot of passive filters and try, try, try until I get a sound that I like, but this would be expensive and not creative at all. To be honest, I like the idea of controlling completely the speakers by searching for good cross-over points and changing the volumes of the different frequency-bands and to listen, listen, listen until I get a good sound and to measure it eventually (and searching, listening,.... again ).Besides, the active cross-over setup gives me more possibilities if I wanted to change a driver/a horn/the complete speaker in the future ![]() The low frequencies will be done by the Marantz amp The mid and high frequencies will be done by two equal amps with a similar gain as the Marantz. Thank you all for your input and ideas, I can't wait untill I can start experimenting and testing ![]() PS: is REW a good program to measure SPL? My father has a good mic so this wouldn't be a problem. Kind regards |
#35 |
just another
REW is a nice program, I've only used the pink noise function for SPL measurements in room, I've not tried the gated measurements with it. I used holmimpulse for that.
REW is also good for measuring impedance curves of the drivers (with a suitable simple jig). Whether active or passive you ultimately want to aim for acoustic slopes of the drivers matching your crossover target, not the filter slopes. for example a 12db flter slope when combined with the driver will often give a 24db accoustic slope (due to the drivers natural rolloff). However if one of the drivers is relatively flat in the range of the crossover frequency then it may only roll off at the filter slope of 12db. It's of course a bit more complex than that, but hope that gives an idea. Tony. |
#36 |
Thinking about 2 stereo amps for the mids and the highs, I read something about 'gain clone amplifiers'. Almost everybody love these kits because they seem affordable and are sounding very nice!
I can choose between 4 x mono LM3886 amps (68W /channel) or 2 x stereo LM4780 amps, which is a dual LM3886. I prefer 2 x LM4780 because it would be cheaper and smaller. Is there a big difference between 4 x mono and 2 x stereo? |
#37 | |
Regards, Pete |
#38 |
Hey, I didn't mean to bring all of the discussion to an END! If you all don't like my question, you can certainly continue with what you were discussing and totally ignore my question. For sure, I've had that happen before.
I realize that what I'm asking is outside of the mainstream of what the thread is about. But I do think that a quick reply by somebody wouldn't hurt. Where are the great defenders of crossing over actively? What I'm suggesting is a frontal assault on the supposed great advantages of active crossovers. Please do excuse my impertinence for posting in this thread. I didn't realize that I wasn't invited to the party. -Pete |
#39 |
just another
It's a fair question Pete
I don't have the knowledge to answer though!! I don't think that you killed the thread. I used to get paranoid about that myself as often I'd post in a thread and it would just stop... you start to wonder sometimes Tony. |
#40 |
Hello everybody,
after reading trough this thread I think a DSP could be a very nice option for this system. miniDSP comes to mind. Home | miniDSP complete freedom in choosing crossover types, slopes, time alignment, ... If you want to try simulating filters (frequency response, phase response, group delay, ..) also take a look at AADE filter design: http://aade.com/filter.htm easy to use and free.
Music is art - Audio is psychoacoustics & engineering Last edited by Mark.Clappers; 3rd October 2012 at 02:54 PM. |
| Keystone Sub Using 18,15,&12 Inch Speakers | weltersys | Subwoofers | 168 | 12th March 2013 01:38 AM |
| Active cross speakers and the tweeter protection cap | wigginjs | Multi-Way | 28 | 1st May 2012 01:15 AM |
| FS: pair Wharfedale 15 inch -W/15/CS(Cloth Surround- 1955/56) $100 | MichaelPublic | Swap Meet | 3 | 10th June 2009 06:49 AM |
