Old 27th October 2003, 06:09 AM   #1
Wright is offline Wright  United States
Send a message via AIM to Wright Send a message via MSN to Wright
Default help with RS drivers
Greetings all,
My friend has recently gotten ahold of 2 Radio Shack 40-1286C 8" drivers. They were a gift from his father so unfortunately he can't exchange them without hurt feelings. I caught an old post on Audio Asylum indicating that these drivers will only work in an open baffle, however that's as far as the description goes. We are willing to try an open baffle, but I'm not sure how large I would need to make the baffle. Obviously the smaller the better but he could probably go as big as necessary for decent (respectively) sound. The TS drivers I have found are as follows:
Fs 53Hz
Vas 1.73 cu ft
Qts 1.16
Qes 1.43
Qms 6.06
Re 7.6 ohms
If you guys might be able to help me out with a baffle size and where on the baffle to mount the speaker, my friend and I would very much appreciate it. Thanks!
George
Old 27th October 2003, 08:49 PM   #2
GM is offline GM  United States
GM's Avatar
Baffle size depends alot on room placement. This driver has a very limited excursion before it begins to distort, so it really needs to be in an as large as possible baffle, like mounted in one of the room's walls, or at the other extreme, on a small one that severely limits LF response. Not what you wanted to hear, I'm sure, but that's the cold hard facts of the matter, so I recommend a box of some sort.
Do a search of the fullrange forum, there's been a number of different cab designs posted there. Personally, I recommend using one of my pipe designs.
http://f18.parsimony.net/forum31999/
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th October 2003, 10:32 PM   #3
Default thanks!
Thanks for the information Greg. I will check out that forum and see if I can find something that will keep him happy.
George
Old 27th October 2003, 10:49 PM   #4
I had a pair of those in the center of 3' x 5' sheets of "wonderboard" leaned into the corners. Worked real well. As GM noted, they won't go real loud, but (IMO) fine for normal listening.
JBL comp drivers, Dayton Reference Sub drivers for auction NO RESERVE pkpickard Swap Meet 1 21st January 2009 03:19 AM
FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers omarmipi Swap Meet 0 19th November 2007 04:21 AM
21" Bass Drivers and Beyma Compression Drivers Magnetar Swap Meet 0 19th November 2006 02:42 AM
Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? thadman Multi-Way 7 11th November 2006 09:11 PM
FS: horn subs, drivers, 'regular' subwoofer drivers John Sheerin Swap Meet 0 1st August 2004 11:33 PM
Page generated in 0.06859 seconds (72.98% PHP - 27.02% MySQL) with 10 queries
