#51 |
#52 |
Sorry I can not help with .frd files. But I have a proposal for the crossover. It may not be the ultimate solution, because the driver data are somewhat doubtful, particularly concerning the tweeter, but better than nothing...
My simulation is based on the data of Zaph (woofer) and the datasheet (tweeter). As I have heard of Tang Band tweeters having spl differences of 4 dB, you will probably have to adjust the resistor in the tweeter path. SimulationImagios.jpg CrossoverImagios.jpg |
#53 | |
What about the high peak at the end, do I understand it right to adjust that with a resitor? Btw. the bassreflex arraived today, just waiting till the glue gets dry ![]() It will take me some time before I finalize it, since I would like to have the final crossover on a custom pcb. but from what your simulation shows it seems decent, I have just only expected a better lower freq. performace, as from WinISD simulations. I will make the next update after playing the box with the vent |
#54 |
I could let you have the frd I created by tracing Zaph's measurements with SplTrace if you're interested ? It should be quite accurate, I was careful and checked it tallied with the original. I also have the zma for the W5 704D if you need it. Sorry, I can't help with the tweeter, I'm using a different one.
It'd be the "raw" frd I'd provide rather than the one's I'm actually using in PCD. Those are the raw driver responses modified with Response Modeler to take into account the effects of my specific baffle and enclosure (this is pretty much a necessity for predicting a decent crossover with PCD. The link I gave earlier in the thread explains how to do this ). |
#55 |
I have used SPL copy but, even thou I done all like in the manual, I never got copied the data...
If you can send me the Spl of the midwoofer that would be great Thanks |
#56 |
Here you go (zipped so as to comply with the forum's attachment management).
#57 |
Thanks I will run some new simulations tomorrow, in the mean while the bassreflex is in place, it helped a lot, I have downloaded a freq. generator and found some unpleasant resonances in higher volumes, I will continue tomorrow to analyse it, but clear is the first order BW just by its self is not the right solution.
#58 |
Hi Imagios,
The resistor in the tweeter section determines the general level of the tweeter. If the tweeter is too loud, increase the resistor to bring it in balance with the woofer. The peak at 23 kHz is another issue. You will have to decide yourself, whether to apply a notch filter or not. But don't expect the peak to be exactly as in the datasheet, as it will probably be different in your box. The low frequency simulation of WinISD is a little bit optimistic, as it does not consider the influence of baffle step and serial inductors (of driver and crossover). This leads to different results like 50Hz and 58Hz. Further I was not sure about your volume and vent tuning and assumed 12.78 litres with a port of 45 x 120 mm. But don't be disappointed, the result is ok in relation to a volume of less than 13 litres! |
#59 | |
After putting the real frl file of the woofer into the system, that quite changed the perspective, I will try to get the tweeter as well to show a complete picture, but just now I know the cap is too high. I will keep you updated
#60 |
OK I did not get the frd file for the tweeter, but I downloadet the one for the Tang Band 25-1166S.frd from rbjaudio.com, according to the datasheet both thweeters are alsmost the same, except mine has this peak at 20kHz
never the less here is the horible result: ![]() I will play around with the crossover to make that more smooth |
| Tang Band W5-1880 | briandk | Full Range | 16 | 1st November 2012 08:45 PM |
| Tang Band W8-1808 / TB ribbon tweeter / Eminence Alpha 15A in OB with U-frame | superlian | Full Range | 3 | 3rd September 2011 11:11 PM |
| Tang Band W5-1685 BIB? | geepee | Full Range | 5 | 16th August 2010 12:00 AM |
| Tang Band W5-704D | revelator | Full Range | 0 | 1st February 2008 06:26 AM |
| Tang Band w5-704s | MITMechE | Multi-Way | 8 | 26th February 2007 02:38 PM |
