Tang Band W5-704 and a TB ceramic tweeter
Old 4th October 2012, 08:54 AM   #31
giralfino is offline giralfino  Italy
giralfino's Avatar
If I'm not reading wrong the QC date, you have some 3 years old drivers, at least the tweeters.
If the woofers are also "old" I'd "massage" them with a 20-40Hz tone at full x-max for some hours. Let them cool and re-measure.
Another suggestion: I use Arta, and I found that the system gives me more realistic TS parameters when I limit the range from 20 to 100 Hz or something like that.
Ralf
Old 4th October 2012, 09:30 AM   #32
imagios is offline imagios  Czech Republic
The driver are old models but I took the first time out of the box, they are new ordered from the shop in september.
Migh te that they are not "broken in" so it may put a different measurement, but definitely
the Vas is impossible, so it must be the measurement.
Old 4th October 2012, 09:59 AM   #33
giralfino's Avatar
I use this method: Jig for Arta
The jig is pretty easy to build, and the Arta can be used in the free version, so IMHO it is worth a try. If the results are consistent between Arta and WT then the problem is in the drivers.
Ralf
Old 4th October 2012, 12:20 PM   #34
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
All TangBand speakers I ever measured are way different from the specs. Usually actual Qt and Fs are considerably higher, and Vas lower than specified. TB is not the only manufacturer where this is the case, but they are one of the worst as far as my experience goes. It's tricky.
But from now on I will be discrete about it.
Old 4th October 2012, 12:59 PM   #35
hmm the question is as well how reliable this dayton audio test is, I used the added mas method with a tape, I cant imagine such a difference, I mean Vas=36lit. ist just not possible for a 5inch speaker, with a Xmax of 3,3mm, there must be a measurement error.
I resimulated the box with my measurement, but with the Vas of TB datasheet, and I will continue as planed, in the most worst case, I just seal the box, and start a new project for a subwoofer.
Old 8th October 2012, 08:31 AM   #36
flaevor is offline flaevor  United States
flaevor's Avatar
how much weight did you add? my understanding is that if you used too much that could be the source of the error.
Old 9th October 2012, 09:26 PM   #37
9,9grams
Old 9th October 2012, 09:39 PM   #38
Ok gents,
here is the new progress, the plates for the housing are ready:
http://hex.dan.sweb.cz/TBBookshelf/20121009_193556.jpg
I as well measured the tweeters:
http://hex.dan.sweb.cz/TBBookshelf/tweeter.bmp
the exact inner volume now is:12,769 l
that gives a vent of 3,5cm x 10 cm, air velocity still OK for 10W input. turning freq. 43Hz
now comes the tricky part, and I will need help with that I need help as most probably most newbies... the cross over.
I mean I know inductors take the low Freq. cap. the high but thats it...
First of all how many level will I need? just one for the cross over freq. between the tweeter and midbass, or shut I use first a highpass to cut off very low freq.?
What freq. would you recoment to get the thweeter working he has a free air res. below 750hz, but the midwoofer goes nice till 5kHz. It seems like a lot of room to select.
Should I as well lowpass the thweeter above lets say 30kHz?
Or would be just one simple cross over betwen midbass and tweeter be the best approach?
Can someone please advice, as I will not be able to do that on my own.
Many thanks upfront
Daniel
Old 10th October 2012, 07:14 PM   #39
OK since no one gave any answer, here is what I have so far,
I would select the cross over freq. at 2500Hz after reading some review on the tweeter
that means a first order BW low pass for the midbass = inductor 0.684 mH (2.512Hz at 10.79 Ohm;6db/octv)
Now the high pass of the tweeter the second order BW=8.376 uF + 0.479 mH (2512Hz 5.347Ohm; 12db/octv.)
would this be correct???
Old 11th October 2012, 07:43 AM   #40
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
Textbook equations will not get you a good sounding speaker.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Tang Band W5-704 and a TB ceramic tweeterHide this!Advertise here!
Tang Band W5-1880 briandk Full Range 16 1st November 2012 09:45 PM
Tang Band W8-1808 / TB ribbon tweeter / Eminence Alpha 15A in OB with U-frame superlian Full Range 3 4th September 2011 12:11 AM
Tang Band W5-1685 BIB? geepee Full Range 5 16th August 2010 01:00 AM
Tang Band W5-704D revelator Full Range 0 1st February 2008 07:26 AM
Tang Band w5-704s MITMechE Multi-Way 8 26th February 2007 03:38 PM
Copyright ©1999-2017 diyAudio
